Ismael Duarte
- Jun 13, 2011
Hi All,
I like to use latest version, even when in Beta. I'm trying this version now and the usually green light at upper right corner is now yellow.
The warning is
Should I do it?
The warning is
The volume DISCO (ZFS) status is UNKNOWN: The pool is formatted using an older on-disk format. The pool can still be used, but some features are unavailable. Upgrade the pool using 'zpool upgrade'. Once this is done, the pool will no longer be accessible on older software versions.
Should I do it?
