FreeNAS-8.0.4-RELEASE-p3-x64 (11703) virtual machine on ESXI 5 with rdm disk problem
ZFSuser
#Summary
I have what appears to be a working Raid Z1 (3 x 1TB rdm) on a FreeNAS-8.0.4-RELEASE-p3-x64 (11703) virtual machine.
However, when testing a failed drive scenario it is not identified by Freenas. All disks are reported as online.
#System Details
Mobo- Gigabyte Z68AP-D3, CPU - i7 2600, RAM - 24GB
VMware ESXi 5.0.0 build-721882
#rdm disk setup for vdev in ZFS pool
vmkfstools -z /vmfs/devices/disks/t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818 /vmfs/volumes/Disk0-120GB-SSD/rdm/D4-1TB.vmdk -a lsilogic
vmkfstools -z /vmfs/devices/disks/t10.ATA_____WDC_WD10EACS2D00D6B0__________________________WD2DWCAU42711813 /vmfs/volumes/Disk0-120GB-SSD/rdm/D5-1TB.vmdk -a lsilogic
vmkfstools -z /vmfs/devices/disks/t10.ATA_____ST31000520AS________________________________________6VX0KLFG /vmfs/volumes/Disk0-120GB-SSD/rdm/D6-1TB.vmdk -a lsilogic
#Testing
dd if=/dev/zero of=output2.img bs=8k count=256k
dd if=/dev/random of=outputrandom2.img bs=8k count=256k
#2GB file test no prob.
[root@FreeNAS] /mnt/Datapool1# dd if=/dev/zero of=output2.img bs=8k count=256k
262144+0 records in
262144+0 records out
2147483648 bytes transferred in 71.431505 secs (30063536 bytes/sec)
dd if=/dev/zero of=output2.img bs=8k count=10240k
dd if=/dev/random of=outputrandom2.img bs=8k count=10240k
#After some ZFS tuning an 80GB file test and 2 x 80GB simultaniously written files test completes without a problem.
#quite standard ZFS tuning, based on analysis of many posts and testing.
#Testing Scenario - Failed disk
#Before
[root@FreeNAS] /mnt/Datapool1# zpool status
pool: Datapool1
state: ONLINE
scrub: none requested
NAME STATE READ WRITE CKSUM
Datapool1 ONLINE 0 0 0
raidz1 ONLINE 0 0 0
da1p2 ONLINE 0 0 0
da2p2 ONLINE 0 0 0
da3p2 ONLINE 0 0 0
errors: No known data errors
#Physically disconnect disk
#After
FreeNAS
[root@FreeNAS] /var/log# cat messages
Jun 28 23:36:51 FreeNAS kernel: mpt1: request 0xffffff80003da170:42337 timed out for ccb 0xffffff01521b3800 (req->ccb 0xffffff01521b3800)
Jun 28 23:36:51 FreeNAS kernel: mpt1: attempting to abort req 0xffffff80003da170:42337 function 0
Jun 28 23:36:51 FreeNAS kernel: mpt1: completing timedout/aborted req 0xffffff80003da170:42337
Jun 28 23:36:51 FreeNAS kernel: mpt1: abort of req 0xffffff80003da170:0 completed
****Appears to repeat in log****
pool: Datapool1
state: ONLINE
raidz1 ONLINE 0 0 0
da1p2 ONLINE 0 0 0
da2p2 ONLINE 0 0 0
da3p2 ONLINE 0 0 0
###VMware###
2012-06-28T13:36:12.110Z cpu2:4396)NMP: nmp_ThrottleLogForDevice:2318: Cmd 0x2a (0x412400721440, 4396) to dev "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" on path "vmhba0:C0:T1:L0" Failed: H:0x0 D:0x2 P:0x0 Valid sense da$
2012-06-28T13:36:12.111Z cpu2:4396)ScsiDeviceIO: 2309: Cmd(0x412400721440) 0x2a, CmdSN 0x8002001f from world 4396 to dev "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x0 0x0.
2012-06-28T13:36:12.114Z cpu6:2171)WARNING: NMP: nmp_IssueCommandToDevice:2954:I/O could not be issued to device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" due to Not found
2012-06-28T13:36:12.114Z cpu6:2171)WARNING: NMP: nmp_DeviceRetryCommand:133:Device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818": awaiting fast path state update for failover with I/O blocked. No prior reservation e
2012-06-28T13:36:12.114Z cpu6:2171)WARNING: NMP: nmp_DeviceStartLoop:721:NMP Device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" is blocked. Not starting I/O from device.
2012-06-28T13:36:12.891Z cpu1:2665)WARNING: NMP: nmpDeviceAttemptFailover:599:Retry world failover device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" - issuing command 0x4124007b81c0
2012-06-28T13:36:12.891Z cpu1:2665)WARNING: NMP: nmpDeviceAttemptFailover:658:Retry world failover device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" - failed to issue command due to Not found (APD), try again...
2012-06-28T13:36:12.891Z cpu1:2665)WARNING: NMP: nmpDeviceAttemptFailover:708:Logical device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818": awaiting fast path state update...
2012-06-28T13:36:13.891Z cpu0:2665)WARNING: NMP: nmpDeviceAttemptFailover:599:Retry world failover device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" - issuing command 0x4124007b81c0
2012-06-28T13:36:13.891Z cpu0:2665)WARNING: NMP: nmpDeviceAttemptFailover:658:Retry world failover device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" - failed to issue command due to Not found (APD), try again...
2012-06-28T13:36:13.891Z cpu0:2665)WARNING: NMP: nmpDeviceAttemptFailover:708:Logical device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818": awaiting fast path state update...
2012-06-28T13:36:43.891Z cpu1:2665)WARNING: NMP: nmpDeviceAttemptFailover:599:Retry world failover device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" - issuing command 0x4124007b81c0
2012-06-28T13:36:43.891Z cpu1:2665)WARNING: NMP: nmpDeviceAttemptFailover:658:Retry world failover device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" - failed to issue command due to Not found (APD), try again...
2012-06-28T13:36:43.891Z cpu1:2665)WARNING: NMP: nmpDeviceAttemptFailover:708:Logical device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818": awaiting fast path state update...
2012-06-28T13:36:52.116Z cpu0:2177)ScsiDeviceIO: 2322: Cmd(0x4124007b81c0) 0x12, CmdSN 0x1362 from world 0 to dev "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" failed H:0x5 D:0x0 P:0x0 Possible sense data: 0x5 0x24 0x0.
2012-06-28T13:36:52.116Z cpu0:2177)WARNING: NMP: nmp_DeviceStartLoop:721:NMP Device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" is blocked. Not starting I/O from device.
2012-06-28T13:36:52.891Z cpu4:14420)WARNING: NMP: nmpDeviceAttemptFailover:562:Retry world restore device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" - no more commands to retry
2012-06-28T13:36:52.891Z cpu4:14420)WARNING: NMP: nmp_IssueCommandToDevice:2954:I/O could not be issued to device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818" due to Not found
2012-06-28T13:36:52.891Z cpu4:14420)WARNING: NMP: nmp_DeviceRetryCommand:133:Device "t10.ATA_____WDC_WD10EARS2D003BB1__________________________WD2DWCAV5P246818": awaiting fast path state update for failover with I/O blocked. No prior reservation
#Moving forward
What other information can I gather for trouble shooting?
Has any one else encountered this behaviour?
Has any one else performed the failure scenario successfully?
My system is in the testing phase, happy to crash and burn.
Thanks in advance.
matlock
I have a very similar setup.
In my experience of a failed drive test I powered down the Freenas vm within esxi5 then powered down esxi5. Removed a drive to test. Powering up esxi after removing the drive I couldn't power on the Freenas vm- I needed to go into the Freenas vm settings and remove the rdm disk that I was testing then I could power on the Freenas vm. Once Freenas powered on - it properly reports a degraded pool.
Did you test in a similar fashion?
-Matlock
ZFSuser
-Matlock
I looked at what may happen in real life.
Simplest thing I can test is the disk, just failing. So I pulled the sata cable out.....and the result is not what I expect. (I can crash and burn.)
I expect the vdev and pool to continue to function, and it does, but one of the drives should be reported as offline. It is not.
So just looking at the FreeNAS GUI/CLI everything looks ok, and will continue to work until the second disk fails.
This would obviously be catastrophic. The vdev could not be recovered being a raidZ1.
matlock
after reviewing what you've written in your OP i'm noticing some oddities... just asking questions to see if it gets us anywhere.
Your rdm disks your passing from esxi to the freenas vm- seem to be 3X120gb ssd devices? thats the name of the datastore within esxi right?- and you named your drives 1tb drives? are they supposed to be 2tb? whats the total available space in your raidz?
whats with the command after the .vmdk "-a lsilogic"
I did a little write-up some time ago about my own raid-z testing - maybe it'll help?
http://forums.freenas.org/showthread.php?6310-esxi-gt-freenas-vm-gt-raidz-testing&highlight=matlock
ZFSuser
Corrected disk size they are 1TB..
Command syntax for adding rdm is as follows:
vmkfstools => command to add disk.
-z => --createrdmpassthru
/vmfs/devices/disks/t10.ATA_____WDC_WD10EARS2D003BB1__________________ ________WD2DWCAV5P246818 => the device the rdm config is pointing at.
/vmfs/volumes/Disk0-120GB-SSD/rdm/D4-1TB.vmdk => directory (which is on the 120GB SSD datastore) and file name.
-a lsilogic => --adaptertype [buslogic|lsilogic|ide], default is 'busLogic'. My disk is using SCSI controller type LSI logic parallel hence lsilogic defined.
#I am not an expert. So I am more than happy to be corrected.
#Now the good news is I check today and the pool is in a degraded state. But why did take so long?
[root@jlzfs25] /mnt/Datapool1# zpool status
pool: Datapool1
state: DEGRADED
status: One or more devices could not be used because the label is missing or
invalid. Sufficient replicas exist for the pool to continue
functioning in a degraded state.
action: Replace the device using 'zpool replace'.
see: http://www.sun.com/msg/ZFS-8000-4J
scrub: scrub completed after 0h8m with 0 errors on Fri Jun 29 07:10:41 2012
Datapool1 DEGRADED 0 0 0
raidz1 DEGRADED 0 0 0
da1p2 UNAVAIL 0 1.05M 0 experienced I/O failures
da2p2 ONLINE 0 0 0
da3p2 ONLINE 0 0 0
#This appears to have a taken a very long time to be reported.
#I will review logs to see if i identify when it is eventually determined to be unavailable. I assume vmware will cause some delay.....
