alexmpr
 - Jul 17, 2018
So I've been reading and trying out different ideas. I am at an impass.
I installed FreeNAS on a 120 gb SSD (overkill space but its a spare I had lying around)
My configuration is as follows.
I receive the following error upon boot.
I receive for basically all drives da0-da7
I ignore those cam errors and just began attempting to see if I could just run the volume manager and upon running them I would receive : MiddleWare Errors. but afterchmodding the drive to
I now receive a CallTimeout Error
I have tried formatting drives, dd the drive. but I am not 100 percent sure I did them correctly. I am somewhat knowledgeable in Linux but Im not sure all the commands I know really work in FreeBSD.
MIDDLEWARE ERROR LOG
CALLBACK ERROR LOG
Error Code asc:31,0 in SCSI
any help would be appreciated thank you in advance. If im missing any futhur information please let me know. sorry for the disorganization of the post in advance also lol...
SuperMICRO MB X8DTU-F LSI 9210-8i (have tried both IT and IR modes) x8 Remanufactured IBM-ESXS ST31000424DD BC28 1TB HDD (I am aiming for raidz2 config) The ssd is: ada0
(da5:mps0:0:7:0): READ(10). CDB: 28 00 74 70 6a 00 00 01 00 00 (da5:mps0:0:7:0): CAM status: SCSI Status Error (da5:mps0:0:7:0): SCSI status: Check Condition (da5:mps0:0:7:0): SCSI sense: MEDIUM ERROR asc:31,0 (Medium format corrupted) (da5:mps0:0:7:0): Field Replaceable Unit: 3 (da5:mps0:0:7:0): Error 5, Retries exhausted
 $ chmod a+w /dev/da7
$ ls -l /dev/daX
# crw-rw--w-  1 root  operator  0xa6 Jul 18 10:13 /dev/da7I now receive a CallTimeout Error
$dd if=/dev/da0 of=/dev/da0/null bs=512 f=1024 (or whatever the second argument is that equal 1024 lol i have it on a notepad somewhere)MIDDLEWARE ERROR LOG
Request Method:	POST
Request URL:	http://192.168.111.93/system/wizard/
Software Version:	FreeNAS-11.1-U5 (8e2a858a1)
Exception Type:	MiddlewareError
Exception Value:
[MiddlewareError: Unable to GPT format the disk "da0": gpart: Input/output error
Exception Location:	./freenasUI/middleware/notifier.py in __gpt_labeldisk, line 359
Server time:	Tue, 17 Jul 2018 15:04:21 -0700
Traceback
Environment:
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
  42.			 response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
  249.			 response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
  178.			 response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
  162.		 return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
  23.				 return view_func(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/views/generic/base.py" in view
  68.			 return self.dispatch(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in dispatch
  237.		 response = super(WizardView, self).dispatch(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/views/generic/base.py" in dispatch
  88.		 return handler(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in post
  300.				 return self.render_done(form, **kwargs)
File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in render_done
  357.								   **kwargs)
File "./freenasUI/system/forms.py" in done
  481.					 _n.create_volume(volume, groups=groups, init_rand=False)
File "./freenasUI/middleware/notifier.py" in create_volume
  752.			 vdevs = self.__prepare_zfs_vdev(vgrp['disks'], vdev_swapsize, encrypt, volume)
File "./freenasUI/middleware/notifier.py" in __prepare_zfs_vdev
  687.								  swapsize=swapsize)
File "./freenasUI/middleware/notifier.py" in __gpt_labeldisk
  359.				 raise MiddlewareError(f'Unable to GPT format the disk "{devname}": {error}')
Exception Type: MiddlewareError at /system/wizard/
Exception Value: [MiddlewareError: Unable to GPT format the disk "da0": gpart: Input/output error
Environment:
Traceback:
  357.								   **kwargs)
Request information
GET
No GET data
POST
Variable	Value
initial_wizard-current_step	'confirm'
__form_id	'dijit_form_Form_5'
FILES
No FILES data
COOKIES
Variable	Value
csrftoken	'********'
fntreeSaveStateCookie	'root%2Croot%2F145%2Croot%2F121%2Croot%2F88%2Croot%2F60%2Croot%2F60%2F74%2Croot%2F60%2F61%2Croot%2F8%2Croot%2F1%2Croot%2F1%2F5%2Croot%2F1%2F2'
sessionid	'o26fattbzgx60mfhtcpwdu88i2se0bgo'
META
Variable	Value
"CALLBACK ERROR LOG
Traceback
	 Request URL:	  http://192.168.111.93/storage/volumemanager/
	 Exception Type:	  CallTimeout
	 Exception Value:
Call timeout
	 Exception Location:	  /usr/local/lib/python3.6/site-packages/middlewared/client/client.py in call, line 429
	 Server time:	  Wed, 18 Jul 2018 10:22:40 -0700
Environment:
Traceback:
File "./freenasUI/storage/views.py" in volumemanager
  148.		 if form.is_valid() and form.save():
File "./freenasUI/storage/forms.py" in save
  309.			 raise e
  298.				 notifier().create_volume(volume, groups=grouped, init_rand=init_rand)
  683.			 c.call('disk.swaps_remove_disks', disks)
File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py" in call
  429.			 raise CallTimeout("Call timeout")
Exception Type: CallTimeout at /storage/volumemanager/
Exception Value: Call timeout
Volume Manager
	 Exception Value:
Call timeout
Traceback
						Environment: Software Version: FreeNAS-11.1-U5 (8e2a858a1) Request Method: POST Request URL: http://192.168.111.93/storage/volumemanager/ Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 42.			 response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249.			 response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178.			 response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162.		 return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23.				 return view_func(request, *args, **kwargs) File "./freenasUI/storage/views.py" in volumemanager 148.		 if form.is_valid() and form.save(): File "./freenasUI/storage/forms.py" in save 309.			 raise e File "./freenasUI/storage/forms.py" in save 298.				 notifier().create_volume(volume, groups=grouped, init_rand=init_rand) File "./freenasUI/middleware/notifier.py" in create_volume 752.			 vdevs = self.__prepare_zfs_vdev(vgrp['disks'], vdev_swapsize, encrypt, volume) File "./freenasUI/middleware/notifier.py" in __prepare_zfs_vdev 683.			 c.call('disk.swaps_remove_disks', disks) File "./freenasUI/middleware/notifier.py" in __prepare_zfs_vdev 683.			 c.call('disk.swaps_remove_disks', disks) File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py" in call 429.			 raise CallTimeout("Call timeout") Exception Type: CallTimeout at /storage/volumemanager/ Exception Value: Call timeout
Request information
GET
No GET data
POST
		  Variable		  Value
			 __all__			  ''
			 volume_name			  'TANK'
			 layout-__all__			  ''
			 layout-TOTAL_FORMS			  '2'
			 layout-INITIAL_FORMS			  '0'
			 layout-0-vdevtype			  'raidz2'
			 layout-0-disks			  'da3'
			 layout-1-vdevtype			  'raidz2'
			 layout-1-disks			  'da7'
			 __form_id			  'dijit_form_Form_0'
FILES
No FILES data
COOKIES
		  Variable		  Value
			 fntreeSaveStateCookie			  'root%2Croot%2F145%2Croot%2F121%2Croot%2F88%2Croot%2F60%2Croot%2F60%2F74%2Croot%2F60%2F61%2Croot%2F8%2Croot%2F1%2Croot%2F1%2F5%2Croot%2F1%2F2%2Croot%2F1%2F6%2Croot%2F123%2Croot%2F10%2Croot%2F10%2F23%2Croot%2F64%2Croot%2F64%2F74%2Croot%2F64%2F71%2Croot%2F64%2F65'
			 sessionid			  'ry9cgoaadandw99rz8eq82wz2b4as0mk'
Variable		 Value
3 31 00 Medium Error - medium format corrupted
