dominator99
- Jan 2, 2014
Hi All
Had a weird problem last night when I shutdown FreeNAS. It appeared to proceed as normal (red warning screen) but I noticed the power LED stayed ON so I left it; ten minutes later the power LED was still ON so I forced a shutdown with the power button.
On reboot I couldn't connect via my network to FreeNAS.
I connected a monitor to FreeNAS to follow the boot procedure & after the initial BIOS routines completed I was left with a blank screen & flashing cursor & no further progress.
I entered the BIOS & noticed the boot order had changed; I normally boot from 2 mirrored Sandisk Cruzer Blade 16GB USB sticks in UEFI (1st & 2nd boot order option) but the first boot option had changed to legacy BIOS boot of the same single USB stick; the original boot order in UEFI had been moved to the 2nd & 3rd boot order option. Resetting the boot order to original setting allowed FreeNAS to boot as normal. All other detected SATA/USB devices had been disabled in the BIOS prior to this problem occurring.
Any ideas as to how the BIOS settings could be changed (the motherboard is only a month old)
