FreeNAS 11, Sabnzbd, Couchpotato & Sonarr
Then it should be there. The Movies directory is gone? Or its empty? Do you have a recent snapshot to roll back to?
Christopher Joyson
Ive installed righ up to Couchpotato install and then tried accessing via the web address 192.168.0.30:5050 but all I get is the site can't be reached.
So I tried service couchpotato status from within teh SABNZB console, with the result "couchpotato not running".
I therfore tried sevice couchpotato start with the following results:
usr/local/etc/rc.d/couchpotato: WARNING: $command_interpreter /usr/local/bin/python != python
Starting couchpotato.
No handlers could be found for logger "root"
  File "/usr/local/CouchPotatoServer/CouchPotato.py", line 133, in <module>
   l = Loader()
  File "/usr/local/CouchPotatoServer/CouchPotato.py", line 52, in __init__
   os.makedirs(self.data_dir)
  File "/usr/local/lib/python2.7/os.py", line 157, in makedirs
   mkdir(name, mode)
OSError: [Errno 13] Permission denied: '/usr/local/CouchPotatoServer/data'
   l = Loader()
   mkdir(name, mode)
/usr/local/etc/rc.d/couchpotato: WARNING: failed to start couchpotato
have I missed something out?
Make sure that user media owns the /usr/local/CouchPotatoServer directory.
Christopher Joyson
Success, Thank you thats Couchpotato Sorted! Now to Fumble my way through the rest.
Congrats. You are learning alot!
Christopher Joyson
So I have as faras installing the SABNZB & Sonarr Packages. however I came upon this on the next command
root@SABNZB:~ # chown -R Media:Media /usr/local/sabnzbd && chown -R Media:Media /usr/local/sonar
chown: /usr/local/sabnzbd: No such file or directory
There is no instance of Sabnzbd or sonar in the Directory usr/local/
I have restarted the jail with the same resut and trie instaling the packages again , of which I got the answer the current packages are the most up to date
What are the contents of /usr/local/? There's no sab or sonarr directory? If not, use locate sabnzbdand locate sonarr
to find them and chown those directories to user Media
Christopher Joyson
Contents of usr/local:
root@SABNZB:/usr/local # ls -l
total 79
drwxr-xr-x   8 Media  Media   22 Apr 16 19:30 CouchPotatoServer
drwxr-xr-x   2 root   wheel  262 Apr 17 11:51 bin
drwxr-xr-x   9 root   wheel   12 Apr 17 11:51 etc
drwxr-xr-x  10 Media  Media   25 Apr 18 09:54 headphones
drwxr-xr-x  23 root   wheel   61 Apr 17 11:51 include
drwxr-xr-x   2 root   wheel	9 Apr 15 13:18 info
drwxr-xr-x  16 root   wheel  360 Apr 17 11:51 lib
drwxr-xr-x   4 root   wheel	4 Apr 17 11:50 libdata
drwxr-xr-x   4 root   wheel	4 Apr 17 11:51 libexec
drwxr-xr-x   7 root   wheel	7 Apr 15 13:18 man
drwxr-xr-x   3 root   wheel	3 Apr 17 11:51 mono
drwxr-xr-x   2 root   wheel	4 Apr 15 13:18 openssl
drwxr-xr-x   2 root   wheel	6 Apr 15 13:18 sbin
drwxr-xr-x  24 root   wheel   24 Apr 17 11:51 share
For the locate I had to run /usr/libexec/locate.updatedb first, as the database was too small.
they are both located in usr/local/share/
root@SABNZB:/usr/local/share # ls -l
total 107
drwxr-xr-x	3 root  wheel	3 Apr 17 11:51 GConf
drwxr-xr-x	2 root  wheel	8 Apr 17 11:51 aclocal
drwxr-xr-x	3 root  wheel	3 Apr 17 11:51 bash-completion
drwxr-xr-x	2 root  wheel	3 Apr 15 13:18 certs
drwxr-xr-x   27 root  wheel   27 Apr 17 11:51 doc
drwxr-xr-x	3 root  wheel	3 Apr 15 13:18 emacs
drwxr-xr-x	6 root  wheel	6 Apr 17 11:50 examples
drwxr-xr-x	3 root  wheel	3 Apr 17 11:51 gdb
drwxr-xr-x	3 root  wheel	4 Apr 17 11:51 gettext
drwxr-xr-x	3 root  wheel	3 Apr 15 13:18 git-core
drwxr-xr-x	6 root  wheel	6 Apr 17 11:51 glib-2.0
drwxr-xr-x	2 root  wheel   34 Apr 17 11:51 libgc-mono
drwxr-xr-x   72 root  wheel   72 Apr 17 11:51 licenses
drwxr-xr-x  102 root  wheel  103 Apr 17 11:51 locale
drwxr-xr-x	3 root  wheel	3 Apr 17 11:51 mono-2.0
drwxr-xr-x	2 root  wheel   46 Apr 15 13:18 nano
drwxr-xr-x	2 root  wheel   17 Apr 15 13:17 readline
drwxr-xr-x	9 root  wheel	9 Apr 17 11:51 sabnzbdplus
drwxr-xr-x	2 root  wheel	4 Apr 15 13:18 sgml
drwxr-xr-x	4 root  wheel   73 Apr 17 11:51 sonarr
drwxr-xr-x	4 root  wheel	6 Apr 15 13:18 xml
drwxr-xr-x	3 root  wheel	3 Apr 12 19:06 zsh
so my new comand is
chown -R Media:Media /usr/local/share/sabnzbdplus && chown -R Media:Media /usr/local/share/sonarr
Christopher Joyson
Ive notice your downloaded sabnzbplus but are only using sabnzbd in your commands, should they be sabnzbplus?
Christopher Joyson
Hi I had to service sabnzbd start to allow SABnzbd to create the Sabznbd.ini file I then stopped sabnzbd to update the file and restarted.
Christopher Joyson
I did the portsnap fetch update && portmaster -aBd
what didtat do it seemed to take forever and asked many questions, I just said yes to all butI haven't gat a scooby-do of what it all meant!
So you should have everything up and running now?
I've notice your downloaded sabnzbplus but are only using sabnzbd in your commands, should they be sabnzbplus?
I'm going to do a final version. I'll follow my own instructions from scratch and make changes as necessary. I wrote those out from memory, and obviously some things have changed.
Christopher Joyson
what so I look at when Sonarr doesnt appear to be picking anything up?
Is it setup properly to download and sab as well?
Christopher Joyson
Sabnzbd is doing fine with couchpotato, Sonnarr has SABNZBD's api. Port and address. category tv. all the indexers are ok.
The other funny thing is it doesnt find many TV shows.
I'm currently having to search for shows myself and then rename them with filebot.
it doesnt recognise the two shows in the folder either.
Christopher Joyson
ive found there is a sonarr folder both usr/local/and usr/local/share. the one in usr/local had the owner as Media:Wheel. so I changed this to Media:Media.
Sonarr has not chenged with its workings.
What indexers are you using?
Christopher Joyson
I use NZBGeek, OZNZB & NZBplanet all passed the connection test, they also worked with Sonarr before.
Sonarr isnot picking up on TV shows, and also not snatching anything.
Christopher Joyson
OK Sonar seems to have started itself , however couchpotato apperars to have stopped altogether even after a restart of the jail. No output on a browser.
I use the shell from Freenas's GUI and ssometimes it stops responding when I do a iocage restart SABNZB or similar it will just stop with a blank line and a flashing box where the cursur should be.
Christopher Joyson
I have found these two errors in the Couchpotato log
04-20 11:09:12 ERROR [chpotato.core._base._core] LXML not available, please install for better/faster scraping support: `http://lxml.de/installation.html`
04-20 11:09:12 ERROR [chpotato.core._base._core] OpenSSL not available, please install for better requests validation: `https://pyopenssl.readthedocs.org/en/latest/install.html`: Traceback (most recent call last):
  File "/usr/local/CouchPotatoServer/couchpotato/core/_base/_core.py", line 84, in dependencies
	import OpenSSL
ImportError: No module named OpenSSL
