Hi!
Here's my scenario. I'd like to setup FreeNAS-11 replication between two remote servers over an openvpn tunnel. Hopefully a common scenario.
I could get openvpn installed/setup in a FreeNAS jail and was able to successfully connect to the remote FreeNAS server.
For the FreeNAS replication to work, would I need to install openvpn into the root OS? Researching other responses - sounds like its not advised to install in root OS. If this is true, then is there some way to have the FreeNAS replication task work over the jail IP address?
Thanks!
Thanks!
