Hello Freenas community,
I am new here and this question has been asked already a "few" times.
Unfortunately I have been 3 days non stop at it and just can't get it right.
The idea:
To have CIFS shares working with FreeIPA user authentication.
The steps I've taken so far:
Added cifs service to freeipa (ipa.xsorgan.local) for my freenas (freenas.xsorgan.local).
Created privilege with read ability for ipanthash and ipantsecurityidentifier
Added the privilege to Cifs service.
Added Kerberos Realm "XSORGAN.LOCAL" with KDC, Admin Server and Password Server set to "ipa.xsorgan.local"
Exported the keytab and imported it into FreeNAS.
Running
Created a SMB share on FreeNAS GUI and gave it owner: calin group: calin permission and set permission type to Windows.
The Freeipa User and Groups appear in the permissions drop-down in GUI.
I recently tried importing my freeipa CA of the domain to FreeNAS and setup TLS Encryption Mode on LDAP settings of FreeNAS which didn't break anything it seems.
Here are 3 screenshots of LDAP and Samba settings in FreeNAS:
I am also a bit confused about the idmap range but I'd say the once that interests me is inside the idmap settings of LDAP?
Running
I am a little lost but think that I might be close to getting this to work.
Trying to access the share on Windows 10 gives me this inside samba log:
All without success.
The idea:
Running
ldapsearch -h ipa.xsorgan.local -Y GSSAPI uid=calin ipaNTHash
on my FreeNAS returns success and the ipaNTHash so this seems correct.Created a SMB share on FreeNAS GUI and gave it owner: calin group: calin permission and set permission type to Windows.
Running
net idmap check
in command line of my FreeNAS I get:Code:
root@freenas:~ # net idmap check check database: /var/db/samba4/winbindd_idmap.tdb Invalid USER HWM 824000001: should be 1 Invalid GROUP HWM 824000001: should be 90000003 uid hwm: 0 gid hwm: 90000002 mappings: 2 other: 3 invalid records: 0 missing links: 0 invalid links: 0 0 changes:
[2018/04/02 13:38:32.406926, 3] ../auth/ntlmssp/ntlmssp_server.c:454(ntlmssp_server_preauth) Got user=[calin] domain=[XSORGAN] workstation=[RAVEN-XS] len1=24 len2=316 [2018/04/02 13:38:32.407000, 3] ../source3/param/loadparm.c:3856(lp_load_ex) lp_load_ex: refreshing parameters [2018/04/02 13:38:32.407095, 3] ../source3/param/loadparm.c:543(init_globals) Initialising global parameters [2018/04/02 13:38:32.407223, 3] ../source3/param/loadparm.c:2770(lp_do_section) Processing section "[global]" [2018/04/02 13:38:32.408059, 2] ../source3/param/loadparm.c:2787(lp_do_section) Processing section "[Calin]" [2018/04/02 13:38:32.408291, 2] ../source3/param/loadparm.c:2787(lp_do_section) Processing section "[Video]" [2018/04/02 13:38:32.408524, 3] ../source3/param/loadparm.c:1598(lp_add_ipc) adding IPC service [2018/04/02 13:38:32.408557, 3] ../source3/auth/auth.c:189(auth_check_ntlm_password) check_ntlm_password: Checking password for unmapped user [XSORGAN]\[calin]@[RAVEN-XS] with the new password interface [2018/04/02 13:38:32.408579, 3] ../source3/auth/auth.c:192(auth_check_ntlm_password) check_ntlm_password: mapped user is: [XSORGAN]\[calin]@[RAVEN-XS] [2018/04/02 13:38:33.466373, 3] ../source3/lib/smbldap.c:626(smbldap_start_tls) StartTLS issued: using a TLS connection [2018/04/02 13:38:33.466416, 2] ../source3/lib/smbldap.c:841(smbldap_open_connection) smbldap_open_connection: connection opened [2018/04/02 13:38:33.468945, 3] ../source3/lib/smbldap.c:1063(smbldap_connect_system) ldap_connect_system: successful connection to the LDAP server [2018/04/02 13:38:33.470687, 3] ../source3/auth/check_samsec.c:399(check_sam_security) check_sam_security: Couldn't find user 'calin' in passdb. [2018/04/02 13:38:33.470725, 2] ../source3/auth/auth.c:332(auth_check_ntlm_password) check_ntlm_password: Authentication for user [calin] -> [calin] FAILED with error NT_STATUS_NO_SUCH_USER, authoritative=1 [2018/04/02 13:38:33.470769, 2] ../auth/auth_log.c:760(log_authentication_event_human_readable) Auth: [SMB2,(null)] user [XSORGAN]\[calin] at [Mon, 02 Apr 2018 13:38:33.470746 CEST] with [NTLMv2] status [NT_STATUS_NO_SUCH_USER] workstation [RAVEN-XS] remote host [ipv4:192.168.77.107:65159] mapped to [XSORGAN]\[calin]. local host [ipv4:192.168.77.207:445] [2018/04/02 13:38:33.470815, 3] ../auth/auth_log.c:591(log_no_json) log_no_json: JSON auth logs not available unless compiled with jansson [2018/04/02 13:38:33.470840, 3] ../source3/auth/auth_util.c:1626(do_map_to_guest_server_info) No such user calin [XSORGAN] - using guest account Tried loging in with XSORGAN\calin XSORGAN.LOCAL\calin calin@XSORGAN calin@XSORGAN.LOCAL
