ovalcoconut
- Feb 11, 2018
![ybgbATC.png](https://i.imgur.com/ybgbATC.png)
The above image is a problem I'm getting when connecting to my debian VM via VNC. This happens on all resolutions Ive tried: 1920x1080, 1024x768, 1280x960, and 1280x1024. This happens when I connect using VNC viewer, and the web VNC that FreeNAS provides.
My system specs are:
Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
16222MB RAM
FreeNAS-11.1
My VM specs are:
1 Virtual CPU
4096 MiB RAM
50 GB zvol
Debian 9.3.0-amd64-cinnamon.iso
When I press the up and down arrow keys, the selection changes, so the issue seems to be with the how it's being displayed. I pressed the right arrow key to see if anything happened, and the OS started, and put me into the desktop successfully. With perfectly functioning graphics, and cinnamon did it's job with no issues. This issue stayed through multiple restarts.
I really don't know where this issue is coming from. Once Debian boots up, everything is fine. The console echo displays properly, it's just this menu that I can't read.
Is it the fault of Debian, FreeNAS, or myself?
I can provide additional pictures/information if needed.
