My Hardware Setup:
- I am using a licensed ESXi v7 host with a single VM on it.
- The single VM has FreeNAS v11.3 on it and nothing more.
- The FreeNAS VM is setup with 2 cores, 8GB memory, a single 50GB (thick provisioned) disk for the FreeNAS OS, and 4 additional (and equally sized) 1.8TB sized disks to be used in a raidz1.
My FreeNAS Setup:
I was able to successfully set this up over a week ago and have been using the system to store my backups on ever since. I have one share setup that uses all of the space of the four 1.8TB from my raidz1 (so roughly 5.2TB of total storage on my share.
The Issue:
Yesterday, I got an error that my backups weren't working. When I dug into the error it was saying that the backup location was not accessible.
- I first attempted to browse to the shared path via File Explorer (within Windows 10) but it errored out because the location was also not accessible.
- I then tried to ping the IP of my FreeNAS VM and it replied back with a 2ms response (so looked fine from this angle).
- I then opened my web browser and tried to access the FreeNAS web interface by the IP (as I always have in the past week to manage it), but instead of taking me to the Username and Password fields to login, it just showed a generic message "Connecting to FreeNAS ... Make sure the FreeNAS system is powered on and connected to the network"
- Next, I opened the console to the FreeNAS VM in ESXi and reviewed the latest logging on the screen but did not see anything relevant. I proceeded to press the Enter key and the main menu/options appeared so I decided to just reboot it (option #10). Upon doing this, as it went through the process to reboot, it hung on multiple services trying to shut things down. After 15 minutes it had still not progressed, so I hard powered off the VM and then turned it back on. As soon as it was powered on there was just a blank/black screen with a flashing cursor in the top right corner - and that's now all it does. Doesn't matter how many times you reboot it nor how long you wait (I waited 4 hours), it goes straight to this flashing cursor.
- Basically, at this point it does not even attempt to boot. If you leave the console open to the VM and power it on, as soon as you click "power on" within 1/2 second you are at the blank/black screen with the flashing cursor. It does not attempt to do anything.
- After spending 6 more hours of trying anything/everything you can think of (way too much to list here), I decided to power off this VM and just create a brand new one and re-install FreeNAS 11.3 from scratch. Now I have a brand new VM, new disk (single 50GB for the OS), FreeNAS 11.3 installed and configured with the settings I want (just no additional attached storage yet), and everything is working fine. I can reboot it as well and everything works as expected. So next, I power this new VM off and attached the original four 1.8TB storage disks from the original VM to this new VM. As soon as I power the new VM back on, BAM! - I am immediately right back at the blank/black screen with the flashing cursor.
So the issue is this, for whatever reason, whenever the additional storage I want to use is attached to the FreeNAS VM - instant blank/black screen when powering on the VM. As soon as you remove all the additional attached storage (leaving only the 50GB disk with FreeNAs on it attached to the VM), then it boots into FreeNAS just fine and everything works, well, except for the fact that my storage still isn't there, which is the whole purpose in even having FreeNAS, ugh... I've spent hours more trying to find any article online that could possibly help me with this, but I've found nothing. I am hoping someone here might have an idea of something I can try.
**Update**
I did have an idea as I was writing this, and that was to remove the additional storage and then power on the VM. Once it gets to the FreeNAS boot menu, I pressed the spacebar to pause things from booting. While it was paused, I then went back and added the four additional storage disks I had been using in the raidz1, and pressed Enter to let FreeNAS continue to boot. Nearly an hour later, FreeNAS finally booted, but not to the main menu like it normally does - where you have the 1-11 options. It was just prompting me to login with the username. Odd. I then tried the web browser and it came up as it should and I was able to get logged in. All my original settings and things are there from when I first set it up a week ago, but the Storage Pool is gone. It just shows the pool name I had setup with "?UNKNOWN" next to it. Ugh.
So even now, it's still not booting properly, and even after trying to trick it by adding the storage after the fact it took an hour to boot and the storage pool is not there, so that was a no-go.
Any additional help/advice is greatly appreciated. Thanks in advance!
Jeep
My FreeNAS Setup:
The Issue:
**Update**
Jeep
