The_REAL_keyser_soze
- Jun 30, 2020
Hello Everyone,
I've had FreeNas up and running without issues since pre 11 and have not had any issues until upgrading to 11.3 Stable and installing new drives.
11.1 U3 boots fine with all drives, but errors on the because of the upgrade and changes to the share
On re-boot my system hangs on BTX Loader when booting with 11.3-U3.2 . (See attached image)
The only work-around that will get me up and running is to remove all the hot-swap drives that are used by FreeNas and only have the single SSD boot drive. Once the system starts loading FreeBSD, I can put the drives in, and all works as before. As long as there are less than 4 drives seen by the BIOS, the system will boot into 11.3.
I have tried all of the "fixes" I have read on the site. (And on others with FreeBSD) I've tried turning on raid, I'm on the latest BIOS (2005 LOL), no USB, etc, etc.
This seems like an issue in the code from 11.1 to 11.3. I am a complete novice with FreeBSD, so if you need any more information, please ask.
Thanks!!
System Specifics
Supermicro 846TQ-R900B Chassis
Supermicro H8DME-2 Motherboard
Dual Six-Core AMD Opteron(tm) Processor 2419 CPU's
48GB RAM
Boot drive is SSD connected into
Thanks!!
System Specifics
48GB RAM
