Oriann
- Dec 15, 2018
Guys, serious question here...
I got now up and running 11.3 beta 1 BUT how to update jails that are still 11.2-patchlevel whatever?
When using
Found command
And no command works as expected or with errors.
Here are the docs from where I have used info and code: https://iocage.readthedocs.io/en/latest/advanced-use.html
When using
pkg update it shows me now kernel mismatch and ask me if I want to IGNORE_OSVVERSION=yesFound command
iocage upgrade -r 11.3-RELEASE jailname, made snapshot for sure and after jails migration to newer version I cannot do iocage console jail1 any more because no login is valid and therefore no password too. Does this command works or it is broken ? Or does somebody worked out this ? Only functional command to get into jail is jexec 9 tcsh but after entering iocage it show this:unknown@jailname:/ #And no command works as expected or with errors.
