- Apr 24, 2020
@Patrick M. Hausen, it's actually
iocage upgrade -r 11.4-RELEASE scratch.iocage upgrade -r 11.4-RELEASE scratch.freebsd-version inside your jail say?He's already at 11.4-p5 and wants to update to 11.4-p6 - so I stand by what I wrote.it's actuallyiocage upgrade -r 11.4-RELEASE scratch
root@freenas[~]# iocage exec scratch freebsd-version scratch is not running, starting jail Command output: 11.4-RELEASE-p6 root@freenas[~]# iocage list -l +-----+--------------+------+-------+------+-----------------+-----------------------+-----+----------+ | JID | NAME | BOOT | STATE | TYPE | RELEASE | IP4 | IP6 | TEMPLATE | +=====+==============+======+=======+======+=================+=======================+=====+==========+ | 56 | scratch | off | up | jail | 11.4-RELEASE-p5 | epair0b|192.168.1.158 | - | - | +-----+--------------+------+-------+------+-----------------+-----------------------+-----+----------+
It's in /mnt/<pool>/iocage/jails/scratch/config.json. You can edit that file if you are careful.Is there an easy way to synchronize these?
root@freenas[~]# iocage exec radarr freebsd-version 11.4-RELEASE-p5 root@freenas[~]# iocage update radarr Snapshot: Tank/iocage/jails/radarr@ioc_update_11.4-RELEASE-p5 created. * Updating radarr to the latest patch level... src component not installed, skipped Looking up update.FreeBSD.org mirrors... 3 mirrors found. Fetching metadata signature for 11.4-RELEASE from update4.freebsd.org... done. Fetching metadata index... done. Fetching 2 metadata patches.. done. Applying metadata patches... done. Inspecting system... done. Preparing to download files... done. Fetching 9 patches..... done. Applying patches... done. The following files will be updated as part of updating to 11.4-RELEASE-p6: /bin/freebsd-version /lib/libcrypto.so.8 /rescue/[ /rescue/atmconfig /rescue/badsect /rescue/bectl /rescue/bsdlabel /rescue/bunzip2 /rescue/bzcat /rescue/bzip2 /rescue/camcontrol /rescue/cat /rescue/ccdconfig /rescue/chflags /rescue/chgrp /rescue/chio /rescue/chmod /rescue/chown /rescue/chroot /rescue/clri /rescue/cp /rescue/csh /rescue/date /rescue/dd /rescue/devfs /rescue/df /rescue/dhclient /rescue/disklabel /rescue/dmesg /rescue/dump /rescue/dumpfs /rescue/dumpon /rescue/echo /rescue/ed /rescue/ex /rescue/expr /rescue/fastboot /rescue/fasthalt /rescue/fdisk /rescue/fsck /rescue/fsck_4.2bsd /rescue/fsck_ffs /rescue/fsck_msdosfs /rescue/fsck_ufs /rescue/fsdb /rescue/fsirand /rescue/gbde /rescue/geom /rescue/getfacl /rescue/glabel /rescue/gpart /rescue/groups /rescue/gunzip /rescue/gzcat /rescue/gzip /rescue/halt /rescue/head /rescue/hostname /rescue/id /rescue/ifconfig /rescue/init /rescue/ipf /rescue/iscsictl /rescue/iscsid /rescue/kenv /rescue/kill /rescue/kldconfig /rescue/kldload /rescue/kldstat /rescue/kldunload /rescue/ldconfig /rescue/less /rescue/link /rescue/ln /rescue/ls /rescue/lzcat /rescue/lzma /rescue/md5 /rescue/mdconfig /rescue/mdmfs /rescue/mkdir /rescue/mknod /rescue/more /rescue/mount /rescue/mount_cd9660 /rescue/mount_msdosfs /rescue/mount_nfs /rescue/mount_nullfs /rescue/mount_udf /rescue/mount_unionfs /rescue/mt /rescue/mv /rescue/nc /rescue/newfs /rescue/newfs_msdos /rescue/nos-tun /rescue/pgrep /rescue/ping /rescue/ping6 /rescue/pkill /rescue/poweroff /rescue/ps /rescue/pwd /rescue/rcorder /rescue/rcp /rescue/rdump /rescue/realpath /rescue/reboot /rescue/red /rescue/rescue /rescue/restore /rescue/rm /rescue/rmdir /rescue/route /rescue/routed /rescue/rrestore /rescue/rtquery /rescue/rtsol /rescue/savecore /rescue/sed /rescue/setfacl /rescue/sh /rescue/shutdown /rescue/sleep /rescue/spppcontrol /rescue/stty /rescue/swapon /rescue/sync /rescue/sysctl /rescue/tail /rescue/tar /rescue/tcsh /rescue/tee /rescue/test /rescue/tunefs /rescue/umount /rescue/unlink /rescue/unlzma /rescue/unxz /rescue/vi /rescue/whoami /rescue/xz /rescue/xzcat /rescue/zcat /rescue/zdb /rescue/zfs /rescue/zpool /usr/include/openssl/asn1.h /usr/lib/libcrypto.a /usr/lib/libcrypto_p.a /usr/lib32/libcrypto.a /usr/lib32/libcrypto.so.8 /usr/lib32/libcrypto_p.a src component not installed, skipped Installing updates... done. radarr has been updated successfully. root@freenas[~]# iocage list -l +-----+--------------+------+-------+------+-----------------+-----------------------+-----+----------+ | JID | NAME | BOOT | STATE | TYPE | RELEASE | IP4 | IP6 | TEMPLATE | +=====+==============+======+=======+======+=================+=======================+=====+==========+ | 44 | radarr | off | up | jail | 11.4-RELEASE-p5 | epair0b|192.168.1.17 | - | - | +-----+--------------+------+-------+------+-----------------+-----------------------+-----+----------+ root@freenas[~]# iocage exec radarr freebsd-version 11.4-RELEASE-p6
@Mannekino any issues with going from 11.2 to TrueNAS? Is the upgrade pretty straight-forward / simple? Any special instructions or guide that you followed?
