Freenas 11.2-U7 - Plugin Installation Error
Ladowali
Hi Gurus,
I am trying to install plex plugin and getting the attached error. Can someone look and advise how I can fix this. I even tried installing Emby and getting same error.
Thanks
Ladowali
can someone tell me how to remove the old files/plugins if it left any files even after deleting the plugins. It just stuck me at one point where I cannot go further. I am just thinking on buying new hard drive and copy over my data so I can totally destroy/format my drives to restart from scratch.
it would be great help if someone points me in right direction.
Thanks
Kcaj
Have you changed any permissions on your datasets?
Maybe the command iocage clean --help will point in the right direction. Be careful there is potential to delete data!
