Freenas 11.2-U7 - Plex Plugin web link not opening
Ladowali
Hi Group,
I have reinstalled new freenas 11.2-U7 on a 120GB SSD and installed Plex Plug in and required windows shares. I can open the shared folder through \\freenas but cannot open the plex web link page through the Management button on the Plex Plugin. It says "The site can't be reached. The link should be "http://192.168.0.33:32400/web".
Any idea what could be wrong?
Thanks
pschatz100
Without any system details, it is not possible to make an informed comment. However, the message would seem to indicate that something in your networking is not set up properly. Make certain you have set up the network parameters for the Plex jail properly - be sure that VNET is enabled.
Try searching the forum for more comments about this kind of problem.
Ladowali
Ok, I have deleted the Plex Plugin and even reinstall freenas 11.2-U7 by formatting my SSD. Now when I try to install Plex Plugin, I get the attached error. Can someone suggest on how to fix this. Thx
