Spencer Skinner
- Dec 22, 2016
Hi guys
Moved over to 11.2-RC1 today and decided to rebuild my Plex server using the new IOCage jails instead of the old byhve system. Having issues with the PMS jail being able to mount my media storage area, when it adds it to the mounts I can see the folders for my music and movies etc, bit then i cant see anything inside them, I have 3 empty folders essentially, the confusion I have is my entire media area has 777 Permissions set recursively throughout. Then other times i try and add the mount and start the Jail I get this
Not sure where to go from here
Thanks guys
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 541, in start
iocage.start()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1628, in start
callback=self.callback
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
self.__start_jail__()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 413, in __start_jail__
silent=self.silent)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError: mount: /mnt/AlphaVolume/AlphaMedia: Operation not supported by device
jail: /sbin/mount -t None -o rw /mnt/AlphaVolume/AlphaMedia /mnt/AlphaVolume/iocage/jails/plex/root/media: failed
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor
Thanks guys
