- 3 usb keys 32gb usb3.0 in different brands (toshiba, samsung, sandisk) configured in triple mirror for boot
- 4 harddrives HGST sas 4GB connected with a mini SAS HD to mini SAS connector and a backpannel
- this supposed to means that the back usb connector [USB3_2] support usb3 only
Jul 13 02:13:53 freenas ada3 at ahcich12 bus 0 scbus11 target 0 lun 0
Jul 13 02:13:53 freenas ada3: <HGST HDN726040ALE614 APGNW7JH> s/n K7J2NAYB detached
Jul 13 02:13:53 freenas (ada3:ahcich12:0:0:0): Periph destroyed
Jul 13 02:13:53 freenas ada1 at ahcich9 bus 0 scbus9 target 0 lun 0
Jul 13 02:13:53 freenas ada1: <HGST HDN726040ALE614 APGNW7JH> s/n K7J2N9LB detached
Jul 13 02:13:53 freenas ada2 at ahcich11 bus 0 scbus10 target 0 lun 0
Jul 13 02:13:53 freenas ada2: <HGST HDN726040ALE614 APGNW7JH> s/n K7J2V84B detached
Jul 13 02:13:53 freenas (ada2:ahcich11:0:0:0): Periph destroyed
Jul 13 02:13:53 freenas (ada1:ahcich9:0:0:0): Periph destroyed
Jul 13 02:13:53 freenas ada0 at ahcich8 bus 0 scbus8 target 0 lun 0
Jul 13 02:13:53 freenas ada0: <HGST HDN726040ALE614 APGNW7JH> s/n K7J0VDTB detached
Jul 13 02:13:53 freenas (ada0:ahcich8:0:0:0): Periph destroyed
Jul 13 02:14:14 freenas uwsgi: [sentry.errors:648] Sentry responded with an error: <urlopen error [Errno 54] Connection reset by peer> (url: https://sentry.ixsystems.com/api/2/store/)
File "/usr/local/lib/python3.6/urllib/request.py", line 1318, in do_open
encode_chunked=req.has_header('Transfer-encoding'))
File "/usr/local/lib/python3.6/http/client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.6/http/client.py", line 964, in send
self.connect()
Jul 13 02:14:14 freenas uwsgi: /site-packages/raven/utils/http.py", line 38, in connect
sock, ca_certs=ca_certs, cert_reqs=ssl.CERT_REQUIRED)
File "/usr/local/lib/python3.6/ssl.py", line 1149, in wrap_socket
ciphers=ciphers)
File "/usr/local/lib/python3.6/ssl.py", line 814, in __init__
self.do_handshake()
File "/usr/local/lib/python3.6/ssl.py", line 1068, in do_handshake
self._sslobj.do_handshake()
File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
ConnectionResetError: [Errno 54] Connection reset by peer
File "/usr/local/lib/python3.6/site-packages/raven/transport/threaded.py", line 174, in send_sync
super(ThreadedHTTPTransport, self).send(data, headers)
File "/usr/local/lib/python3.6/site-packages/raven/transport/http.py", line 47, in send
ca_certs=self.ca_certs,
File "/usr/loca
Jul 13 02:14:14 freenas uwsgi: l/lib/python3.6/site-packages/raven/utils/http.py", line 66, in urlopen
return opener.open(url, data, timeout)
File "/usr/local/lib/python3.6/urllib/request.py", line 526, in open
response = self._open(req, data)
File "/usr/local/lib/python3.6/urllib/request.py", line 544, in _open
'_open', req)
File "/usr/local/lib/python3.6/urllib/request.py", line 504, in _call_chain
result = func(*args)
File "/usr/local/lib/python3.6/site-packages/raven/utils/http.py", line 46, in https_open
return self.do_open(ValidHTTPSConnection, req)
File "/usr/local/lib/python3.6/urllib/request.py", line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 54] Connection reset by peer>
Jul 13 02:14:14 freenas uwsgi: [sentry.errors.uncaught:670] ['OperationalError: database is locked', ' File "django/core/handlers/exception.py", line 42, in inner', ' File "django/core/handlers/base.py", line 249, in _legacy_get_response', ' File "django/core/handlers/base.py", line 178, in _get_response', ' File "freenasUI/freeadmin/middleware.py", line 162, in process_view', ' File "django/contrib/auth/decorators.py", line 22, in _wrapped_view', ' File "django/contrib/auth/decorators.py", line 46, in <lambda>', ' File "django/utils/functional.py", line 234, in inner', ' File "django/utils/functional.py", line 380, in _setup', ' File "django/contrib/auth/middleware.py", line 24, in <lambda>', ' File "django/contrib/auth/middleware.py", line 12, in get_user', ' File "django/contrib/auth/__init__.py", line 187, in get_user', ' File "django/contrib/auth/backends.py", line 102, in get_user', ' File "django/db/models/manager.py", line 85, in manager_method',
Jul 13 02:14:14 freenas uwsgi: ' File "django/db/models/query.py", line 379, in get', ' File "django/db/models/query.py", line 238, in __len__', ' File "django/db/models/query.py", line 1087, in _fetch_all', ' File "django/db/models/query.py", line 54, in __iter__', ' File "django/db/models/sql/compiler.py", line 835, in execute_sql', ' File "django/db/backends/utils.py", line 64, in execute', ' File "django/db/utils.py", line 94, in __exit__', ' File "django/utils/six.py", line 685, in reraise', ' File "django/db/backends/utils.py", line 64, in execute', ' File "freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute', ' File "freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry', ' File "freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry']
- after reboot the drives will be detected but the usb key in the [usb2] connector will not be detected in Freenas (but is detected in the BIOS)
- all 3 usb keys are recognized and one the front usb2 ports is not usable as expected
