somnambulist7
- Aug 19, 2013
Hello! Long time lurker, but after the last few days trials and head scratching I had to post. I've searched through the forums, but not seen much that was similar. The one thread with my initial issue (https://forums.freenas.org/index.php?threads/freenas-11-install-error-no-symbol-table.55477/) did not produce any suggestions that worked for me.
My FreenNAS 9.10 had been happily purring away for ages, but yesterday (Sunday, 29th July) I logged into admin only to be greeted with a blinky light of doom. Sure enough the USB key had decided to start failing and could not be repaired. Well, time to update anyway so 11.1 here I come. My FreeNAS box is a Xeon E3-1245 V2, 16GB Kingston ECC RAM, Intel DBS1200 KPR mITX motherboard, LSI 9211-8i (flashed to IT), 6x3TB WD Red drives in a Node 304 case.
From OSX I successfully restored 11.1 to an 8GB SanDisk USB key, all seemed in order. FreeNAS 9 shutdown, keyboard, screen connected; booted up, entered the boot menu and selected the USB key; that immediately gave me: "invalid symbol table, no kernel installed, press any key to continue". Try again, same message. Google for said message, 1 post in FreeNAS forums that suggested legacy boot mode. My motherboard BIOS has hardly any settings, but I did try non-EFI boot, no difference. Try again, re-dd just in case. Nope; notta, nothing. I then tried totally disabling EFI booting; still no dice. Checked for a BIOS update - none, and the board is of course discontinued. The error seems to be something to do with Grub but way beyond my skill level to do anything about.
Fast forward to today and I downloaded 11.2 Beta, figured there might be a more recent Grub on that. Restored it to the same USB key and got a "device not configured" message but it apparently finished OK. That's odd, lets try it anyway. Nope nothing. Failed to boot this time with a set of errors and a system halt. Re-applied the image. Same deal and the same device error from dd. At this point maybe a bad USB key? However...
With latest and greatest not working, how about 9.10? Using the exact same USB key that had previously failed with 11.1 and 11.2, I tried the archive 9.10 release ISO. dd finished without any errors and very interestingly OSX diskutil would actually read the partition details (11.2 seemed to be broken). I booted from this and the FreeNAS installer started and finished. After a few more hiccups, I'm back up and running now on 9.10.2 U6. So it seems like the USB key was fine, so maybe the instructions for 11.1 need updating (http://doc.freenas.org/11/install.html#on-os-x)? Has anyone else experienced anything like that?
I am very concerned about even attempting to switch to 11.X and I am left wondering if the root problem is that my motherboard, while being UEFI, is not "proper" UEFI, and might be a 32-bit UEFI with a 64-bit CPU and that is not a compatible configuration. For example: there is no bootable UEFI shell, I have to resort to using a USB key with a custom EFI image (makes firmware updates really fun).
Would this be an indication that I should be thinking about a new motherboard? It is a bit old now (2013) but has worked great until now, but new mobo means probably new CPU and RAM and totally dismantling the case :( (I don't recommend the Node 304 case)
At any rate, I am almost certainly going to buy myself a Mini-XL once pay day is here because right now I have no secondary NAS and this escapade has left me a little uneasy.
