BUILD For anyone looking for a compact chassis/case
joeschmuck
Old Man
Nice, too bad the user manual is not available in English.
Interesting, but I have my doubts regarding cooling, since those fans look a bit too puny.
Jailer
Not strong, but bad
I always question a pull only airflow configuration especially when it comes only from the rear of the case. Air always flows the path of least resistance and I have a hard time believing that the path of least resistance will be over the hard drives. Unless you seal and specifically duct the air over those drives it's going to find another less resistant path to enter.
joeschmuck
Old Man
That is where a smoke stick comes into play, so you can find out the air flow path, but you will need to see inside the case so that is where it gets tricky, but if you are only looking for air flow going into the case, the smoke stick would allow you to see where the air enters the case, not the path once inside the case. I'd be more concerned about the MB staying cool.
