Folder prompts username and password
jucelio_rosa
Boa tarde.
Após uma falha de energia, toda vez que tento acessar uma pasta, ele solicita nome de usuário e senha. Eu uso autenticação no AD. Mesmo que eu digite o nome de usuário e a senha, não consigo acessá-lo. Percebi que o serviço dos Serviços de Diretório está desabilitado. Não consigo habilitá-lo. Tento ativar, mas não posso. Pode ser isso ? O que fazer ?
jucelio_rosa
Good afternoon.
After a power failure, every time I try to access a folder, it prompts for username and password. I use authentication in AD. Even if I enter the username and password, I can't access it. I noticed that the Directory Services service is disabled. I can't enable it. I try to activate, but I can't. Can be it ? What to do ?
anodos
Sambassador
For 11.2 run the following commands in sequence:
rm /etc/directoryservice/activedirectory/config
sqlite3 /data/freenas-v1.db "UPDATE directoryservice_activedirectory SET ad_enable=1"
service ix-hostname start
service ix-kerberos start
service ix-kinit start
klist - verify that you have a kerberos ticket for the AD domain
service ix-pre-samba start
net -k -d 3 ads join - save output of this to post here if the domain join fails
service samba_server onerestart
The above commands do not apply for 11.3 and later.
jucelio_rosa
Good afternoon.
The problem was already solved.
First I tried to follow the steps you indicated, but to no avail.
So I was instructed to check if AD is working well, if AD Sync was working well and then try again to enable the service.
