LimeCrusher
- Nov 25, 2018
I have installed Transmission 2.94_3 through the GUI as a plugin on my FN11.2 and I fail to permanently change the download destination folder.
I have created a mount point with:
Of course, changing the destination folder manually through the WebGUI works: files are downloaded properly (and written) to the source folder of the mount point.
What am I doing wrong folks?
/mnt/mypool/downloadsas source./mnt/mypool/iocage/jails/transmission/root/mnt/downloadsas destination.
/mnt/downloads in the jail but this setting does not survive a plugin/jail restart. I also modified the Transmission's configuration file (precisely /mnt/mypool/iocage/jails/transmission/root/usr/local/etc/transmission/home/settings.json) while the plugin/jail as down but the value of "download-dir" is set back to "/usr/local/etc/transmission/home/Downloads" after a plugin/jail restart while all my other settings survive the restart.Of course, changing the destination folder manually through the WebGUI works: files are downloaded properly (and written) to the source folder of the mount point.
