marcevan
- Dec 15, 2013
I have Couch, SickR, and Headphones and each is configured with Transmission and test successfully in their setups to push torrents into transmission for downloads to be moved to /movies /tv /music respectively under a downloads folder.
Transmission is set to use incomplete folder under local /mnt before moving files to /downloads and the proper move directory underneath.
Couchpotato: works fine
SickRage: works fine
Headphone: no movement of fully completed downloads being moved to /mnt/downloads/music; they are stuck in /mnt/incomplete
Transmission is 777 all folders/files so in /incomplete there are a dozen or so directories for music artists all fully readable/writable.
Transmission's /mnt/incomplete folder is 777 on permissions so all can read/write to it.
Here's transmission's /mnt folder:
drwxrwxrwx 5 nobody nogroup 6 Oct 22 19:04 downloads
drwxrwxrwx 29 nobody nogroup 29 Oct 27 09:36 incomplete
drwxrwxrwx 2 nobody nogroup 2 Dec 23 2014 torrents
Here's transmission's view of it's downloads directory:
drwxrwxrwx 5 nobody nogroup 6 Oct 27 10:04 Movies
drwxrwxrwx 22 nobody nogroup 22 Oct 27 10:04 Music
drwxrwxrwx 2 nobody nogroup 3 Oct 27 09:32 TV
So I don't get why transmission isn't moving from incomplete to downloads/Music for Headphones but does so for SickRage and Couch.
