BobCochran
- Aug 5, 2011
I want to upgrade to FreeNAS 9.2.1. The release notes say:
I'm currently running FreeNAS 9.2.0 with two (2) IBM M1015 (LSI SAS9220-8i) HBA adapters. I bought these off Ebay a long time ago and flashed them into IT mode with version 13.
My questions are:
Can I flash each of my HBA's in place, right in the FreeNAS system I am using, both connected to the motherboard, and without disconnecting either adapter from any of the existing drives?
Is it better to pull each adapter and re-flash it one at a time using a separate system? I have an old Dell box sitting around and that motherboard has a PCIe x16 connector on it. But the motherboard chipset may be Intel-based. It might be a 32-bit processor, too. Presuming this works, could I then restore the adapters to the FreeNAS system, one at a time?
If I put an HBA that has been flashed to "phase 16" into a FreeNAS system that has another adapter which is running "version" (or "phase") 13 firmware, will this cause me problems or will the system run stable?
What is the difference between "phase 16" and "version 16" as referenced by the Release notes?
Many thanks
Bob
			Updated the LSI 6 Gbps HBA driver (mps) to version 16. Please update the firmware of any mps HBAs to phase 16.
My questions are:
Many thanks
Bob
