Revon Tuli
- Feb 25, 2016
Hi there ppl!
I'm new to freenas and don't know where to post my problem.
So. I have installed Freenas on my old computer for learning and free time doing. Nothing special yet, just having fun.
CPU: intel quad core q9650 3ghz.
RAM: 8gb ddr3 4x2gb
2x500gb HDD
http://shop.itema-pg.com/userfiles/editor/file/ds-ESPRIMO-P5731-EStar5.pdf
Install went smoothly, i have set up windows shares and accounts for wife and myself. Works on lan nicely. Except the lag when windows connects to freenas, but once im in my home folder, works without problem. I have 2 other pc on the network with win10 and seven. I decided to step forward and tried to set up SSH so i can access my freenas from the net. (android tablet) I had no success so far. In freenas things are configured. Found some nice guide on the net. Also using duckdns and cron job is running.
First problem is my router.
huawei b315s-22. i have 4g internet and all of our computers connecting to the router with cable.
i tried to forward the port, but i havent find an option for it. Under the Virtual server option i tried open port 22.
Name WAN Port LAN IP Address LAN Port Protocol Status
SSH 22 192.168.100.12 22 tcp on
Thats how it looks right now. I dont know if its right, specially the wan port. i found no information about to freenas ssh and wan port configuration. I cant ping my server and connect to it from my pc (filezilla) either my tablet.
Filezilla tries to connect
fzSftp started, protocol_version=4 after connection timeout.
Also thinking about change the port, because it can be that my isp blocking it, still looking for info in that subject.
After a router/freenas restart ip changes. Is there a way to prevent that?
RAM: 8gb ddr3 4x2gb
2x500gb HDD
