Hi all,
This is my first server build and first time working with a mini-atx case. I figure I'm almost certainly missing something or making a mistake and very much appreciate any guidance I can get. My build is below. The primary goal is to have 2 6TB drives in Raid 1 for backing up key files that are shared by 2 users. The other 2 6TB drives would be for growth - or to use as a media server.
Case: iStarUSA S-35-DE4RD 4x3.5" hotswap mini-ITX tower
Mobo: MSI H310I PRO LGA 1151 Intel Mini ITX Intel Mobo
CPU: Intel i3-8350K Coffee Lake Quad-core 4.0 GHz LGA 1151
PSU: FSP Group Mini ITX/Flex ATX 80 PLUS Gold 400W power supply
RAM: G.SKILL 8GB DDR4 3000 F4-3000C16S-8GISB
HDDs: 4x Seagate 3.5 HDD ST6000NM0034 6TB 7200 RPM Dual SAS 12Gb/s Interface 128MB Cache
SSD (Boot Drive): KingDian N400 32GB M.@ 2242 NGFF SSD
I'm particularly concerned about:
Thank you!
- The M.2 boot disk - compatibility and using that form factor
- The MOBO and Case compatibility
- Whether or not my drives will interface correctly with the case/MOBO
- If this has any serious deficiencies for the media server idea
- How I might be able to cut down on price
Thank you!
