DAXQ
- Sep 5, 2014
Sorry in advance for the long winded question, but I believe it needs background.
I have been running freeNAS for a couple of months now on older hardware [HP Prolaint ML370 G6 - not a slouch server by any means, but certainly older - and not the greatest raid config with its 16 drives set up individually]. I was thrust into a restore with my HP server - one of my main production servers [IBM System x3650 M3] lost a raid controller. So I had to restore my VM's off the HP FreeNAS server last night rather unexpectedly. I use Veeam B&R to take nightly backups of the servers for just this kind of thing.
For my set up, I am using:
The Restore worked great on smaller servers (DC's & Small File servers 60GB - 150GB) however while restoring one of my application specific servers 699GB - it was a different thing - and I am not sure I understand how it worked - by all rights I would have expected the restoration to have failed, but it didn't and I wonder if one of you guys may be able to shed some light on it.
During the restore of the larger VM (Veeam PC restoring from FreeNAS datastore via NFS on a Linux computer to an ESXi server) I got to about 50% ~4hours in - and I heard the FreeNAS server fans kick on - as if the server was rebooting. When I tried to web brows to it, I indeed verified it was rebooting. The Veeam process did not cut out, but did stop moving its progression & %. I watched that server for 10 minutes (the logs even show the gap) rebooting - when it finally got back up - the Veeam process began ticking away again - as if nothing had happened. This happened once more during the night at ~80% - talk about sick to your stomach stress. The second time I had a monitor screen on the FreeNAS box [normally headless] and granted it was about 1AM in the morning I didn't catch much but did see the server go through its entire reboot process [another 10 minutes] and Veeam waited util the stream was available again and carried on as if nothing had happened.
I am sure CIFS would have crapped out completely - so my question(s) are:
How did the NFS mount manage to keep things going between the VeeamPC, the Linux server with the NFS mount and FreeNAS?
Secondly - I sit and listen to these servers daily, and I have never seen/heard the FreeNAS box just randomly reboot like that, making me think it must have had something to do with the restore process that was going on - any suggestions to help me determine how the reboots happened so I can prevent them in the future?
Thirdly - would the best way to speed these larger restores up be to get into 10G network between the servers and backup? Can FreeNAS use those NICs?
(Edit - OK 10G network was a stupid thought, I figured it was more "readily available" and used than it appears it is in its current state).
- Veeam running on a PC
- Veeam connects to a Linux Datastore that is using NFS
- The Linux DataStore is connecting to FreeNAS via NFS mount
- This setup is how I backup and restore the VM's and the backup part has worked very well
