billgreenwood
- Apr 11, 2014
Hi all,
The last machine I built from scratch was state of the art (now ark). I had an AT286 chip, 1MB Ram, 5¼" floppy and a state of the art 3½" drive and a beast of a 20gb HD. It was a beast! But my first FreeNas build will have just a little more power!
After reading many posts on this forum, I've decided on the following for my FreeNAS. Please feel free to add any pointers / critique.
My spec
CASE
Fractal Design Define R4 Black Pearl Mid Tower
MOTHERBOARD
Supermicro MBD-X9SCM-F-O
CPU
INTEL Xeon E3-1230V3 3.3GHz LGA1150
CPU COOLER
Supermicro SNK-P0046A4
RAM
Kingston 32GB 1600MHz DDR3 ECC CL11 DIMM
DRIVES
6 x WD Red 3TB for NAS 3.5-inch
2 EXTRA FANS for venting out the top
Fractal Design Silent Series R2 140mm
PSU
Corsair CP-9020055-UK RM Series RM750 80 Plus Gold 750W ATX/EPS Fully Modular Power Supply Unit
FLASH DRIVE x 3 (one spare - one for upgrades)
Kingston Technology 8 GB USB 2.0 DataTraveler SE9H Flash Drive.
My primary use for the NAS is as a fileserver. I plan to run BitTorrent Sync for an offsite backup to another lower powered NAS for important files. I'll also run an onsite grandfather tape backup routine using retrospect on a macmini for file, unless there are any FreeNAS options on this.
I have a question on the fans which I can't find an answer on the forum. I'd like the fans to draw air through the back and vent it out the top. Somehow the fans must be reversed to blow out? How please is this done please - ok if it is just a case of reversing the fan, just laugh now! You can see i'm a bit out of touch with any own build!
I'll also dabble with the FreeNAS Plex, though I use a macmini for this currently. Unless I find the FreeNAS plugin is better.
I'm also interested in purchasing a UPS. Any recommendations for this will be great. I only need it to keep the system running for 10 mins and perform a controlled shutdown. Can a UPS reboot the NAS when the power comes back on?
I'm based in UK
Thanks
Bill
My spec
CASE
MOTHERBOARD
CPU
CPU COOLER
RAM
DRIVES
PSU
I'm based in UK
Thanks
Bill
