pessimist101
- May 12, 2019
Hi everyone, I'm planning to turn my old build into a NAS using FreeNAS. I've done some research but I'm doing this on a budget so I would appreciate any feedback.
It will just be used for general storage - photos, documents, etc. and only 1-3 concurrent users. Parts I've already got are as follows:
Cooler master MWE Bronze 450
i5-2500 with stock cooler
Intel DQ67OW motherboard
Kingston A400 120GB SSD
Cooler master N300 case
16GB DDR3 1333MHz (4x4GB all mismatched)
I'm thinking of adding 8 of these drives:
WD Blue 2TB 3.5" SATA HDD
I think I want to put them in RAID 6 so I get more than the 8TB I'd get with RAID 10 but still have 2 drive failure tolerance.
I'm thinking of installing FreeNAS on the SSD. I know you can run it from a USB but I don't feel comfortable running it off USB and SSDs are so cheap now anyway.
I'm also thinking of putting another SSD in there (probably same model) for caching, could that improve my write speeds in any way?
Appreciate any feedback, thanks!
