SOLVED files/folders with specials chars not visible in guest filesystem
GregW
I'm using Freenas 9.10-STABLE, latest version.
I've created a jail in which I installed Ubuntu 16.04 LTS.
I shared one folder with the jail. Some files and folders have specials chars (accents).
Files with special chars are visible in the jail shell, but not visible by the guest???
Am I missing some options? I checked, searched, no clue? Maybe the php virtualhost (4.3.12) is too old? Can I upgrade it (how?)?
This is problematic because I set up this jail to install Crashplan, and I'm not backuping all the files....
Gregory.
GregW
I ended up mounting the folders via smb/cifs. I created the files with specials chars (accents) on my windows machine. If I mount the folders on the guest (ubuntu) via samba -> all good.
Not a real solution, but now Crashplan sees all the files.
I also tried with an NFS mount. File appeared with a '?' for each sepcial chars and were not seen by the Crashplan engine.
