Luke Merry
 - Dec 22, 2016
Hello, I just recently set up my first FreeNAS box.  I'm blown away by the awesomeness so far, but there is one issue that I can't seem to figure out.  I'm sure that it's a noobish mistake.  Here's the scenario:
Two jails, each with the same dataset mounted as storage. Both jails have an identical user, created with 'adduser' within each, with the id of a matching top-level freenas user entered as the userid. Both of the users have also been included in the 'wheel' group.
SSHed into one of the jails as said user, I created several folders within the dataset as follows (they didn't start out as 777 permissions but in the course of trying to figure out this problem i changed it to that):
Now, in the same dataset mount on the other jail, I get:
I have a similar issue if i create, say, a windows SMB share on the same dataset. I can create files there but I can't see any of the files that should already be there. Any ideas?
Thank you, kind folks.
[user@jail_a /mnt/share_a]$ ls -al total 83 drwxrwxrwx 6 root wheel 6 Dec 21 18:40 . drwxr-xr-x 3 root wheel 3 Dec 21 18:37 .. drwxrwxrwx 2 user wheel 2 Dec 21 18:40 folder_a drwxrwxrwx 9 user wheel 13 Dec 22 18:01 folder_b drwxrwxrwx 5 user wheel 5 Dec 22 18:01 folder_c
[user@jail_b /mnt/share_a]$ ls -al total 1 drwxr-xr-x 2 root wheel 2 Dec 21 18:37 . drwxr-xr-x 4 root wheel 4 Dec 21 18:37 ..
