I am using FreeNAS 11.2-BETA3. I have setup an iocage jail (FreeBSD 11.2-RELEASE-p4). Installed SVN in it. I also wanted to have my repository on my mail pool, outside of jail. For that I added a mount point in my jail. Everything seems normal until I try to create an empty repository
I see mount point has a plus sign next to it (is this called "sticky bit"?) I suspect that has something to do because I can create/modify/delete files on my mount point
Mount point source: /mnt/pool/share/svnbase
Mount point destination: /mnt/iocage/jails/svn/root/svn
Any help is appreciated.
Thanks & regards,
Ertan
root@svn:~ # svnadmin create /svn/test svnadmin: E000001: Can't set permissions on '/svn/test/db/svn-W1SfvU' svnadmin: E000001: Can't set permissions on '/svn/test/db/svn-W1SfvU': Operation not permitted root@svn:~ #
/svn
in the jail. Some more information from jail:Mount point source: /mnt/pool/share/svnbase
root@svn:~ # ls -l / total 156 -rw-r--r-- 2 root wheel 957 Jun 22 07:34 .cshrc -rw-r--r-- 2 root wheel 474 Jun 22 07:34 .profile -r--r--r-- 1 root wheel 6197 Jun 22 07:34 COPYRIGHT drwxr-xr-x 2 root wheel 47 Oct 14 01:22 bin drwxr-xr-x 9 root wheel 52 Oct 14 01:22 boot dr-xr-xr-x 12 root wheel 512 Oct 17 07:45 dev drwxr-xr-x 27 root wheel 109 Oct 17 07:45 etc lrwxr-xr-x 1 root wheel 8 Oct 14 01:57 home -> usr/home drwxr-xr-x 4 root wheel 56 Jun 22 07:33 lib drwxr-xr-x 3 root wheel 5 Jun 22 07:35 libexec drwxr-xr-x 2 root wheel 2 Jun 22 07:32 media drwxr-xr-x 2 root wheel 2 Jun 22 07:32 mnt drwxr-xr-x 2 root wheel 2 Jun 22 07:32 net dr-xr-xr-x 2 root wheel 2 Jun 22 07:32 proc drwxr-xr-x 2 root wheel 148 Jun 22 07:33 rescue drwxr-xr-x 2 root wheel 7 Oct 17 07:34 root drwxr-xr-x 2 root wheel 137 Jun 22 07:34 sbin drwxrwxr-x+ 2 1000 wheel 2 Oct 17 07:47 svn <--- this is my main pool mount point drwxr-xr-x 6 root wheel 8 Oct 14 02:20 svnbase lrwxr-xr-x 1 root wheel 11 Oct 14 01:21 sys -> usr/src/sys drwxrwxrwt 6 root wheel 8 Oct 17 07:45 tmp drwxr-xr-x 15 root wheel 15 Oct 14 01:57 usr drwxr-xr-x 24 root wheel 24 Oct 17 07:45 var root@svn:~ #
root@svn:~ # df -h Filesystem Size Used Avail Capacity Mounted on pool/iocage/jails/svn/root 1.5T 473M 1.5T 0% / root@svn:~ #
Thanks & regards,
Ertan
