We have an old TrueNAS HA device that we're turning into two FreeNAS systems. We're going to use top shelf for one side, and the bottom for the other. The bottom shelf is attached via an external SAS cable. The top shelf is in the same case as the systems themselves. So both sides are connected to the SAS backplane of the top shelf.
I want to ensure one of the sides doesn't see the drives in the top shelf. I know the TrueNAS version had some method of fencing the drives, but I'm not sure how it worked.
Any suggestions on how I might tell one of the FreeNAS devices to never touch these drives, or even remove them from its sight? I'm not sure there's a hardware method of terminating the connection, but I know there is a software one, because TrueNAS did it. I don't need an HA failover; I just need one side to see the drives, and the other side not to.
Thanks.
Thanks.
