My System:
Mobo - ASRock FM2A85X-ITX
CPU - AMD A4 5300 2-Core Processor
RAM - GeIL 16GB Kit (2x8GB) DDR3 Evo Veloce C9 1333MHz
HDDs - 6x WD Red 3TB
Network card - Intel PCIe CT Gigabit Ethernet Network Card
Boot device - Imation Classic USB 2.0 Flash Drive (8GB)
OS Version - FreeNas 8.3.1 Release P2
Current Setup
The FreeNAS box is currently connected to a gigabit switch, along with 2 Windows PCs and a PoE device, which connects to the router in another room.
Background
FreeNAS is running live from the USB drive as mentioned above - I've created a RAID-Z2 volume with all 6 disks, and a CIFS share to mnt/volume1.
Both PCs have no issue accessing that share and authenticating as root to gain access (haven't set up non-standard user accounts as of yet).
Issue
When I start transferring data (starting a 1.3tb transfer, from an internal SATA HDD to the CIFS share), from either PC, after anywhere between ~2-10 minutes the transfer freezes, and the box itself is displaying "Fatal trap 12: page fault while in kernel mode" - much like the screenshot posted by "MotorSport" in this thread. Apologies I don't have my own screenshot right now - forgot to take one before leaving for work! It's a pretty similar message, just different values for virtual address etc, I'll upload one when possible.
I've tried enabling all of the CIFS Aux settings & the Tunables mentioned by Proto in this post, as well as enabling/disabling a few different combinations of those tunables + doubling the values of arc_max & write_limit_override in an attempt to take the extra RAM into account - No stability change yet.
I tried clearing the config and rebooting the system 2-3 times with Autotune enabled, no change.
I ran a short memtest (~1 hour) with no results - but plan to leave it on overnight tonight to see what comes up.
The hardware's all new so obviously I'm hoping there's nothing wrong with it... but it wouldn't be the first time I've had new system problems caused by bad hardware.
I had a go at running a SMART test, but all I could see how to do was schedule on to start every day \ every hour \ every day \ every month and just wait an hour for it to start - is this the best way of starting the test?
I've updated to the latest BIOS available for my motherboard, didn't seem to make any change.
I did notice late last night that the switch I've been using has had a few issues, causing slow transfer speeds. I'm not sure if that could also be causing this, but I plan to pick up a new Gigabit switch (Linksys SE2500) after work tonight - as well as trying the nightly build of 9.1.
Sorry if I've missed / forgotten anything - Does anyone have an idea of what could be causing the problem?
Cheers!
Current Setup
Background
Issue
Cheers!
