Mannekino
- Nov 14, 2012
First specs of my system:
So I went and purchased three new fans. I got three Noctua NF-F12 PWM fans which have 4-pin connectors and can be PWM controlled. I installed them and selected "Optimal" Fan Mode in the BIOS because I want my server to be as quiet as possible.
Unfortunately things haven't turned out well, the fans keep ramping up and down with 10-15 second intervals. Is there any way I can solve this problem? I found a thread to control fan speeds through IPMI but that only works on the X11 range of motherboards.
Second problem: the "Fan Mode" configuration option doesn't show up for me in the IPMI web interface as shown below. Is there a way to enable it?
Thanks in advance for your help.
- Motherboard: Supermicro X9SCM-F
- Chassis: Fractal Design Node 804
- CPU: Intel Xeon E3-1260L
- CPU cooler: Noctua NH-L9i (this has a 4-pin PWM fan)
- Memory: 32GB ECC (4x 8GB Kingstong ValueRAM KVR1333D3E9SK2/16G)
- HBA: Dell PERC H200 (flashed in IT mode)
- Storage SDD: 2x Samsung PM863 240GB connected through the two onboard SATA3 (6Gb/s) ports
- Storage HDD: 4x Western Digital Red 4TB (connected through the HBA)
- Storage USB: 2x SanDisk Ultra Fit 32GB
