Case Fans Ramping Up and Down
jay.ing
Hi all,
I have just installed some new Artic F12 PWM fans in my case. When i select any other fan profile than 'Full' in the IMPI 'Fan control menu', all the fans ramp up to full and then reduce to min, and so on. Motherboard is a Supermicro X11. Any Ideas??
Thanks
Chris Moore
You need to adjust the threshold speed
jay.ing
WOW thats some thread, will have to get reading!
Chris, i did find a thread where someone was changing the threshold speed, but i couldnt get the 'ipmitool -I lanplus -H nas-sol -U ADMIN -P ADMIN sensor thresh FAN1 lower 300 300 400' to work as it was saying IMPItool could not be found.
This was from the shell though, would i need to stop the boot into freenas and do it at the command line there?
Thanks for the pinters
Chris Moore
What version of FreeNAS are you running?
jay.ing
So i eventually got this working, i found out i had to reset the BMC every time to get the monitoring to work correctly. Thanks all
