Failure to mount NFS within Ubuntu VM
marclar
I have:
  • TrueNAS using the IP 192.168.1.185
  • a dataset named pool0/media owned by root
  • an Ubuntu VM named ubuntu_mk with IP 192.168.1.160
  • an NFS share named /mnt/pool0/media, with "Mapall User" set to root
I can ping TrueNAS from Ubuntu and Ubuntu from TrueNAS.
However, when I try to mount the NFS share using the command:
sudo mount -t nfs 192.168.1.185:/mnt/pool0/media /mnt
I get the error NFS4: Couldn't follow remote path.
Kind of stuck... anyone know how to troubleshoot this problem?
In the NFS service options is NFS4 ticked?
marclar
It is - this is what I currently have:
I have two differences and im mounting fine in Linux Mint. Not sure if related. I have never seen this particular error. I have NFS3 ownership model ticked and I have UDP unticked. I mount using an identical command with no problem.
marclar
Hm... okay, thanks. Maybe I'll try with Linux Mint.
Did you do anything special with "Mapall User" or "Mapall Group" for your share? I only have one of those set but I'm kind of clueless here.
I do not have anything selected in those, but my users are all identical across systems with matching UIDs and such, ymmv. My user owns the data and my user is doing the mounting. Works beautifully. In fact im even doing the mounting across a site to site VPN and its flawless albeit slower.
