• Currently using VMware at work? We want to hear from you.
    Thinking of making a switch from VMware? We'd love to hear your thoughts and feedback about which hypervisor you have been researching or already using. Click here to vote and share your thoughts! You can vote HERE!
"Failed to open..."
sdntive
I have been trying to installed freenas8 onto an 8Gb usb stick and when it gets to the point to installed the file in the command prompt it exits. I have tried both i386 and amd64 with the same results with the iso image and the expanded full files. This is what I get every time, freenas.img was the iso amd64 file. Any help would be great. Thanks
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Trevor>desktop\temp\physdiskwrite.exe -u freenas.img
physdiskwrite v0.5.2 by Manuel Kasper <mk@neon1.net>
Searching for physical drives...
Information for \\.\PhysicalDrive0:
Windows: cyl: 38913
tpc: 255
spt: 63
Information for \\.\PhysicalDrive1:
Windows: cyl: 38913
tpc: 255
spt: 63
C/H/S: 16383/16/63
Model: ST9320421AS
Serial number: 5TJ0QDSV
Firmware rev.: SD14
Information for \\.\PhysicalDrive2:
Windows: cyl: 121597
tpc: 255
spt: 63
Information for \\.\PhysicalDrive3:
DeviceIoControl() failed on \\.\PhysicalDrive3.
Information for \\.\PhysicalDrive4:
Windows: cyl: 973
tpc: 255
spt: 63
Which disk do you want to write? (0..4) 4
WARNING: that disk is larger than 2 GB! Make sure you're not accidentally
overwriting your primary hard disk! Proceeding on your own risk...
About to overwrite the contents of disk 4 with new data. Proceed? (y/n) y
Failed to open freenas.img - exiting.
ancavazz
your problem is dos. solution:
C:\Users\Trevor>cd desktop\temp\
C:\Users\Trevor\desktop\temp>physdiskwrite.exe -u freenas.img
