failed smart self-check. back data now!
Hostigal
in var/log/messages say this continuos
but zpool status is ok, is a problem? Or is warning before failure
view image
Robert Trevellyan
Pony Wrangler
It appears to be telling you that da15, an SSD, has reached its wear limit. The reason zpool status is clear is because it hasn't noticed any data corruption. The fact that a SMART attribute has reached its limit does not mean you will immediately experience data loss, but it does mean you should at the very least have a cold spare on hand.
Hostigal
Ok, I mean, the ssd is reaching the limit of its life ... but I understand that if everything is ok now and it is a z2, even if that disk fails nothing will happen, simply zpool will be degraded and you can change that disk by another one, It's like this
greetings and thanks.
