hello, I am working on a freenas Raid 5 with two failed 2 tb disks out of 4.
I was able to image(DD) one of the failed disks 100% to an Identical 2tb disk.
so now i have three disks of the 4, yet the pool cannot mount because of two missing members using GUID tags and obviously one disk does not belong(different guid).
I attempted mounting the raid in ubuntu, but its response is it "can" mount it but does not.
is there any way around this....usually i would mount all disks in a virtual disk utility with , block size, raid algorithm and offset and then extract data.
thank you
thank you
