fail2ban für nextcloud jail sichern
shadow010
Hallo zusammen
Ich wollte mein Nextcloud Jail mittsels fail2ban absichern. fail2ban reagiert und mittels Befehl: fail2ban-client status nextcloud sehe ich auch das gebannt wurde, ich aber leider immer noch auf die nextcloud zugreiffen kann. Ich vermutte es liegt an einer Fehlkonfiguration in der action.d/ipfw-nextcloud.local oder an der ipfw.rules .
Im Log des fail2ban steht oft alredy banned:
2021-05-29 00:36:54,898 fail2ban.server [7150]: INFO --------------------------------------------------
2021-05-29 00:36:54,899 fail2ban.server [7150]: INFO Starting Fail2ban v0.11.2
2021-05-29 00:36:54,899 fail2ban.server [7150]: INFO Daemon started
2021-05-29 00:36:54,900 fail2ban.observer [7150]: INFO Observer start...
2021-05-29 00:36:54,940 fail2ban.database [7150]: INFO Connected to fail2ban persistent database '/var/db/fail2ban/fail2ban.sqlite3'
2021-05-29 00:36:54,941 fail2ban.jail [7150]: INFO Creating new jail 'nextcloud'
2021-05-29 00:36:54,949 fail2ban.jail [7150]: INFO Jail 'nextcloud' uses pyinotify {}
2021-05-29 00:36:54,954 fail2ban.jail [7150]: INFO Initiated 'pyinotify' backend
2021-05-29 00:36:54,956 fail2ban.datedetector [7150]: INFO date pattern `',?\\s*"time"\\s*:\\s*"%Y-%m-%d[T ]%H:%M:%S(%z)?"'`: `,?\s*"time"\s*:\s*"Year-Month-Day[T ]24hour:Minute:Second(Zone offset)?"`
2021-05-29 00:36:54,956 fail2ban.filter [7150]: INFO maxRetry: 1
2021-05-29 00:36:54,956 fail2ban.filter [7150]: INFO findtime: 43200
2021-05-29 00:36:54,956 fail2ban.actions [7150]: INFO banTime: 86400
2021-05-29 00:36:54,956 fail2ban.filter [7150]: INFO encoding: UTF-8
2021-05-29 00:36:54,956 fail2ban.filter [7150]: INFO Added logfile: '/var/log/nextcloud.log' (pos = 56404, hash = bcf05742b9aa2c23cbaf33e3d3c1e9ea96170ac8)
2021-05-29 00:36:55,094 fail2ban.jail [7150]: INFO Jail 'nextcloud' started
2021-05-29 00:36:55,173 fail2ban.actions [7150]: NOTICE [nextcloud] Restore Ban 444.333.111.22
2021-05-29 00:37:45,202 fail2ban.filter [7150]: INFO [nextcloud] Found 444.333.111.22 - 2021-05-29 00:37:45
2021-05-29 00:37:45,828 fail2ban.actions [7150]: WARNING [nextcloud] 444.333.111.22 already banned
2021-05-29 00:38:42,279 fail2ban.filter [7150]: INFO [nextcloud] Found 444.333.111.22 - 2021-05-29 00:38:42
2021-05-29 00:38:42,923 fail2ban.actions [7150]: WARNING [nextcloud] 444.333.111.22 already banned
2021-05-29 00:39:39,502 fail2ban.filter [7150]: INFO [nextcloud] Found 444.333.111.22 - 2021-05-29 00:39:39
2021-05-29 00:39:40,033 fail2ban.actions [7150]: WARNING [nextcloud] 444.333.111.22 already banned
Meine Installation:
/etc/rc
firewall_enable="YES"
firewall_script="/usr/local/etc/ipfw.rules"
fail2ban_enable="YES"
/usr/local/etc/ipfw.rules <-- hier ist vermutlich der Fehler drin?
IPF="ipfw -q add"
ipfw -q -f flush
#loopback
$IPF 10 allow all from any to any via lo0
$IPF 20 deny all from any to 127.0.0.0/8
$IPF 30 deny all from 127.0.0.0/8 to any
$IPF 40 deny tcp from any to any frag
# statefull
$IPF 50 check-state
$IPF 60 allow tcp from any to any established
$IPF 70 allow all from any to any out keep-state
$IPF 80 allow icmp from any to any
#firewall rule used by Fail2Ban to block traffic
$IPF 90 deny all from 'table(1)' to any
# open port DNS (53)
# http (80), https (443) etc
$IPF 150 allow tcp from any to any 443 in
$IPF 160 allow tcp from any to any 443 out
$IPF 170 allow udp from any to any 53 in
$IPF 175 allow tcp from any to any 53 in
$IPF 180 allow udp from any to any 53 out
$IPF 185 allow tcp from any to any 53 out
$IPF 200 allow tcp from any to any 80 in
$IPF 210 allow tcp from any to any 80 out
$IPF 220 allow tcp from any to any 22 in
$IPF 230 allow tcp from any to any 22 out
# deny and log everything
 $IPF 500 deny log all from any to any
/usr/local/etc/fail2ban/jail.d/nextcloud.conf
[nextcloud]
enabled  = true
filter  = nextcloud
action  = ipfw-nextcloud
logpath  = /var/log/nextcloud.log
maxretry =  1
port = 80,443
protocol = tcp
/usr/local/etc/fail2ban/filter.d/nextcloud.conf
[Definition]
_groupsre = (?:(?:,?\s*"\w+":(?:"[^"]+"|\w+))*)
failregex = ^\{%(_groupsre)s,?\s*"remoteAddr":"<HOST>"%(_groupsre)s,?\s*"message":"Login failed:
            ^\{%(_groupsre)s,?\s*"remoteAddr":"<HOST>"%(_groupsre)s,?\s*"message":"Trusted domain error.
datepattern = ,?\s*"time"\s*:\s*"%%Y-%%m-%%d[T ]%%H:%%M:%%S(%%z)?"
/usr/local/etc/fail2ban/action.d/ipfw-nextcloud.conf <-- oder Fehler hier???
[Definition]
actionstart =
actionstop =
actioncheck =
actionban = ipfw table 1 add <ip>
actionunban = ipfw table 1 delete <ip>
[Init]
port = https
localhost = 192.168.101.3
blocktype = unreach port
/usr/local/www/nextcloud/config/condig.php
'logtimezone' => 'Europe/Zurich',
'Log_authfailip' => true,
'logfile' => '/var/log/nextcloud.log',
'loglevel' => 2,
fail2ban-regex /var/log/nextcloud.log /usr/local/etc/fail2ban/filter.d/nextcloud.conf
funktioniert ebenfalls und gibt:
Lines: 89 lines, 0 ignored, 77 matched, 12 missed
aus. Ich hoffe Ihr könnt mir weiterhelfen.
Gruss und Danke
micneu
ist das nicht eher ein nextcloud thema, auch wenn du es auf einem free/truenas laufen hast?
shadow010
Hallo Micneu
und die schicken mich hier hien mit der selben Aussage. Mit Nextcloud hat es weniger zu tun da die bannung ja funktioniert. Es hat vermutlich eher mit dem Action zu tun oder der falschen Firewall config???
Gruss und Danke
micneu
hast du auf dem truenas eine firewall, welche denn?
Ich denke er meint die ipfw config in seinem nextcloud jail
Ist das nicht gewünscht? fail2ban soll doch nur greifen, wenn zuviel traffic von der gleichen ip kommt. Willst du dich aussperren?
Außderm wäre noch interessant wie du aus dem Internet auf dein NC jail zugreifst. Port-forward in deinem router? reverse-proxy vor der nc-Instanz? Ist das jail direkt am NAT?
Danach entscheidet sich ja die config von fail2ban und ipfw. Die Doku schon konsultiert? https://docs.nextcloud.com/server/19/admin_manual/installation/harden_server.html?highlight=fail2ban
Ich sehe auch gerade, du hast von Patrick schon die Empfehlung zum install script von dan bekommen. Bist du dem gefolgt? Wenn das eine Plugin installation ist, kannst du auch mit dem nächsten update direkt von vorne mit der config anfangen. Machs lieber richtig, per hand im jail.
