P
Patrik
Guest
I have searched through the forums but havent found anything that can help me sort my problem out, wich is as follows...
When i write to the disks via any variant of filecopy (smb) the speed is between 150 - 700 Kb/s!!!
I can however use ftp and via 5 parallell connections get a whooping 200 - 300 Kb/s each and so reach ca 1,5 Mb/s.
From the same setup i can, without problem, via smb stream full 1080p DTS video!!
Thats at least a read speed at around 35-40 Mb/s.
Why the big difference?
And why do i have such extreme low performance when writing to the disks?
The disks are formatted for zfs (no raid) and shared via cifs and attached at the SATA-3 ports with ahci mode enabled.
The things i have found in other questions regarding slow writespeeds; Large RW Support, Send Files with sendfile(2) and AIO, is all enabled.
Edit 2: In the disk settings I have transfermode - auto. Could this be a problem with sata3?
In the dropdown you only have SATA 1.5Gbit/s and SATA 3Gbit/s. There is no SATA 6Gbit/s.... Should I manually select SATA 3Gbit/s?
Is there any risk of loosing data on the disk if I change this setting??
The FreeNAS 8.0.1-BETA4 system is installed on a 4 GB CFcard on the VIA VT6415 controller.
Edit 1: I have upgraded to RC1 and now i get around 1,5Mb/s on averege. The issue prevails....
I have the following hardware configuration:
Motherboard: ASUS P8H67 REV 3.0 H67 S-1155
Processor: INTEL CORE I3 2120 3.30GHZ 3MB S-1155
Memory: 2 x Kingstone DIMM DDR3 4GB 1333MHZ CL9
Storage Controllers:
Intel® H67(B3) chipset:
2 x SATA 6Gb/s port(s)
4 x SATA 3Gb/s port(s)
Support Raid 0, 1, 5, 10
VIA VT6415 controller:
1 x UltraDMA 133/100/66 for up to 2 PATA devices
HDD: 2 x WD CAVIAR GREEN 2TB SATA/600 64MB
Network: Gb all the way.
/Patrik
/Patrik
