Extreme performance drop after awhile - needs reboot
zef
I've been running my TrueNas setup for about 2 years now. Been great so far - but I've recently hit a bit a snag and and could use your expertise!
It's a pretty basic setup:
VM with 32 GB RAM & 2 cores
4 - 4TB SATA in RAIDZ1 that are passed through from the host to the NAS system
1 Pool, 2 Datasets (one new one w/ deduped enabled, other not deduped)
I'm trying to transfer about 1 TB of backups from a dataset (which dedup isn't enabled) to a new dataset (which is enabled) to take advantage of deduplication for backups. The process goes like this:
1) copy one of the 25GB daily backup files OUT of the un-deduped dataset to a linked system which temporarily hold it in RAM
2) then copy the data back into the deduped dataset from the temp system
3) clear the temporary hold location
4) repeat
For awhile (30-60 minutes) it runs great! Getting fantastic dedup rates and everything. Then after some time it looks to hit a wall. The read rate TANKs hard and the only thing I have found that fixes it is a full reboot of the NAS system.
Thing's I've tried:
updated to the most recent version TrueNAS-13.0-U4 from 12.0-U8.1
set vfs.zfs.arc.meta_min=8589934592 (suspected ARC metadata thrashing)
disable smb service
The only thing I can get to fix it is doing a full reboot of the system in which case the speeds return to normal.
Here's a visual so you can get the idea. Let me know what other logs or data you want to see. Thanks in advance!!!
root@NAS[~]# arc_summary
ZFS Subsystem Report                            Fri Mar 31 00:07:07 2023
FreeBSD 13.1-RELEASE-p7                                    zpl version 5
Machine: NAS.landoscloud.com (amd64)                    spa version 5000
ARC status:                                                      HEALTHY
        Memory throttle count:                                         0
ARC size (current):                                    74.9 %   23.2 GiB
        Target size (adaptive):                        75.8 %   23.5 GiB
        Min size (hard limit):                         3.2 %  1022.4 MiB
        Max size (high water):                           30:1   30.9 GiB
        Most Frequently Used (MFU) cache size:         58.2 %   12.2 GiB
        Most Recently Used (MRU) cache size:           41.8 %    8.8 GiB
        Metadata cache size (hard limit):              75.0 %   23.2 GiB
        Metadata cache size (current):                  4.0 %  941.6 MiB
        Dnode cache size (hard limit):                 34.5 %    8.0 GiB
        Dnode cache size (current):                     1.7 %  136.6 MiB
ARC hash breakdown:
        Elements max:                                             427.3k
        Elements current:                             100.0 %     427.3k
        Collisions:                                               316.6k
        Chain max:                                                     4
        Chains:                                                    20.4k
ARC misc:
        Deleted:                                                    3.5M
        Mutex misses:                                               3.1k
        Eviction skips:                                            84.5k
        Eviction skips due to L2 writes:                               0
        L2 cached evictions:                                     0 Bytes
        L2 eligible evictions:                                 189.9 GiB
        L2 eligible MFU evictions:                      1.1 %    2.1 GiB
        L2 eligible MRU evictions:                     98.9 %  187.7 GiB
        L2 ineligible evictions:                               240.5 GiB
ARC total accesses (hits + misses):                                35.8M
        Cache hit ratio:                               94.0 %      33.6M
        Cache miss ratio:                               6.0 %       2.2M
        Actual hit ratio (MFU + MRU hits):             93.9 %      33.6M
        Data demand efficiency:                        64.0 %       1.7M
        Data prefetch efficiency:                     < 0.1 %       1.4M
Cache hits by cache type:
        Most frequently used (MFU):                    83.8 %      28.2M
        Most recently used (MRU):                      16.2 %       5.4M
        Most frequently used (MFU) ghost:               0.2 %      59.0k
        Most recently used (MRU) ghost:               < 0.1 %      16.3k
Cache hits by data type:
        Demand data:                                    3.3 %       1.1M
        Prefetch data:                                < 0.1 %         14
        Demand metadata:                               96.7 %      32.5M
        Prefetch metadata:                            < 0.1 %       5.7k
Cache misses by data type:
        Demand data:                                   29.1 %     628.7k
        Prefetch data:                                 63.0 %       1.4M
        Demand metadata:                                7.6 %     164.0k
        Prefetch metadata:                              0.3 %       6.7k
DMU prefetch efficiency:                                            1.8M
        Hit ratio:                                     51.6 %     949.9k
        Miss ratio:                                    48.4 %     889.3k
L2ARC not detected, skipping section
Tunables:
        abd_scatter_enabled                                            1
        abd_scatter_min_size                                        4097
        allow_redacted_dataset_mount                                   0
        anon_data_esize                                                0
        anon_metadata_esize                                            0
        anon_size                                             2015012864
        arc.average_blocksize                                       8192
        arc.dnode_limit                                                0
        arc.dnode_limit_percent                                       10
        arc.dnode_reduce_percent                                      10
        arc.evict_batch_limit                                         10
        arc.eviction_pct                                             200
        arc.grow_retry                                                 0
        arc.lotsfree_percent                                          10
        arc.max                                                        0
        arc.meta_adjust_restarts                                    4096
        arc.meta_limit                                                 0
        arc.meta_limit_percent                                        75
        arc.meta_min                                          8589934592
        arc.meta_prune                                             10000
        arc.meta_strategy                                              1
        arc.min                                                        0
        arc.min_prefetch_ms                                            0
        arc.min_prescient_prefetch_ms                                  0
        arc.p_dampener_disable                                         1
        arc.p_min_shift                                                0
        arc.pc_percent                                                 0
        arc.prune_task_threads                                         1
        arc.shrink_shift                                               0
        arc.sys_free                                                   0
        arc_free_target                                           173776
        arc_max                                                        0
        arc_min                                                        0
        arc_no_grow_shift                                              5
        async_block_max_blocks                      18446744073709551615
        autoimport_disable                                             1
        btree_verify_intensity                                         0
        ccw_retry_interval                                           300
        checksum_events_per_second                                    20
        commit_timeout_pct                                             5
        compressed_arc_enabled                                         1
        condense.indirect_commit_entry_delay_ms                        0
        condense.indirect_obsolete_pct                                25
        condense.indirect_vdevs_enable                                 1
        condense.max_obsolete_bytes                           1073741824
        condense.min_mapping_bytes                                131072
        condense_pct                                                 200
        crypt_sessions                                                 0
        dbgmsg_enable                                                  1
        dbgmsg_maxsize                                           4194304
        dbuf.cache_shift                                               5
        dbuf.metadata_cache_max_bytes               18446744073709551615
        dbuf.metadata_cache_shift                                      6
        dbuf_cache.hiwater_pct                                        10
        dbuf_cache.lowater_pct                                        10
        dbuf_cache.max_bytes                        18446744073709551615
        dbuf_state_index                                               0
        ddt_data_is_special                                            1
        deadman.checktime_ms                                       60000
        deadman.enabled                                                1
        deadman.failmode                                            wait
        deadman.synctime_ms                                       600000
        deadman.ziotime_ms                                        300000
        debug                                                          0
        debugflags                                                     0
        dedup.prefetch                                                 0
        default_bs                                                     9
        default_ibs                                                   15
        delay_min_dirty_percent                                       60
        delay_scale                                               500000
        dirty_data_max                                        3430569164
        dirty_data_max_max                                    4294967296
        dirty_data_max_max_percent                                    25
        dirty_data_max_percent                                        10
        dirty_data_sync_percent                                       20
        disable_ivset_guid_check                                       0
        dmu_object_alloc_chunk_shift                                   7
        dmu_offset_next_sync                                           1
        dmu_prefetch_max                                       134217728
        dtl_sm_blksz                                                4096
        embedded_slog_min_ms                                          64
        flags                                                          0
        fletcher_4_impl [fastest] scalar superscalar superscalar4 sse2 ssse3 avx2 avx512f
        free_bpobj_enabled                                             1
        free_leak_on_eio                                               0
        free_min_time_ms                                            1000
        history_output_max                                       1048576
        immediate_write_sz                                         32768
        initialize_chunk_size                                    1048576
        initialize_value                            16045690984833335022
        keep_log_spacemaps_at_export                                   0
        l2arc.exclude_special                                          0
        l2arc.feed_again                                               1
        l2arc.feed_min_ms                                            200
        l2arc.feed_secs                                                1
        l2arc.headroom                                                 2
        l2arc.headroom_boost                                         200
        l2arc.meta_percent                                            33
        l2arc.mfuonly                                                  0
        l2arc.noprefetch                                               1
        l2arc.norw                                                     0
        l2arc.rebuild_blocks_min_l2size                       1073741824
        l2arc.rebuild_enabled                                          0
        l2arc.trim_ahead                                               0
        l2arc.write_boost                                        8388608
        l2arc.write_max                                          8388608
        l2arc_feed_again                                               1
        l2arc_feed_min_ms                                            200
        l2arc_feed_secs                                                1
        l2arc_headroom                                                 2
        l2arc_noprefetch                                               1
        l2arc_norw                                                     0
        l2arc_write_boost                                        8388608
        l2arc_write_max                                          8388608
        l2c_only_size                                                  0
        livelist.condense.new_alloc                                    0
        livelist.condense.sync_cancel                                  0
        livelist.condense.sync_pause                                   0
        livelist.condense.zthr_cancel                                  0
        livelist.condense.zthr_pause                                   0
        livelist.max_entries                                      500000
        livelist.min_percent_shared                                   75
        lua.max_instrlimit                                     100000000
        lua.max_memlimit                                       104857600
        max_async_dedup_frees                                     100000
        max_auto_ashift                                               14
        max_dataset_nesting                                           50
        max_log_walking                                                5
        max_logsm_summary_length                                      10
        max_missing_tvds                                               0
        max_missing_tvds_cachefile                                     2
        max_missing_tvds_scan                                          0
        max_nvlist_src_size                                            0
        max_recordsize                                           1048576
        metaslab.aliquot                                         1048576
        metaslab.bias_enabled                                          1
        metaslab.debug_load                                            0
        metaslab.debug_unload                                          0
        metaslab.df_alloc_threshold                               131072
        metaslab.df_free_pct                                           4
        metaslab.df_max_search                                  16777216
        metaslab.df_use_largest_segment                                0
        metaslab.find_max_tries                                      100
        metaslab.force_ganging                                  16777217
        metaslab.fragmentation_factor_enabled                          1
        metaslab.fragmentation_threshold                              70
        metaslab.lba_weighting_enabled                                 1
        metaslab.load_pct                                             50
        metaslab.max_size_cache_sec                                 3600
        metaslab.mem_limit                                            25
        metaslab.preload_enabled                                       1
        metaslab.preload_limit                                        10
        metaslab.segment_weight_enabled                                1
        metaslab.sm_blksz_no_log                                   16384
        metaslab.sm_blksz_with_log                                131072
        metaslab.switch_threshold                                      2
        metaslab.try_hard_before_gang                                  0
        metaslab.unload_delay                                         32
        metaslab.unload_delay_ms                                  600000
        mfu_data_esize                                       12987881984
        mfu_ghost_data_esize                                  1798595072
        mfu_ghost_metadata_esize                                25378304
        mfu_ghost_size                                        1823973376
        mfu_metadata_esize                                      40105472
        mfu_size                                             13099472896
        mg.fragmentation_threshold                                    95
        mg.noalloc_threshold                                           0
        min_auto_ashift                                                9
        min_metaslabs_to_flush                                         1
        mru_data_esize                                        7640310784
        mru_ghost_data_esize                                 16270403584
        mru_ghost_metadata_esize                                90891776
        mru_ghost_size                                       16361295360
        mru_metadata_esize                                     362282496
        mru_size                                              9407368704
        multihost.fail_intervals                                      10
        multihost.history                                              0
        multihost.import_intervals                                    20
        multihost.interval                                          1000
        multilist_num_sublists                                         0
        no_scrub_io                                                    0
        no_scrub_prefetch                                              0
        nocacheflush                                                   0
        nopwrite_enabled                                               1
        obsolete_min_time_ms                                         500
        pd_bytes_max                                            52428800
        per_txg_dirty_frees_percent                                   30
        prefetch.array_rd_sz                                     1048576
        prefetch.disable                                               0
        prefetch.max_distance                                   67108864
        prefetch.max_idistance                                  67108864
        prefetch.max_sec_reap                                          2
        prefetch.max_streams                                           8
        prefetch.min_distance                                    4194304
        prefetch.min_sec_reap                                          1
        read_history                                                   0
        read_history_hits                                              0
        rebuild_max_segment                                      1048576
        rebuild_scrub_enabled                                          1
        rebuild_vdev_limit                                      33554432
        reconstruct.indirect_combinations_max                       4096
        recover                                                        0
        recv.queue_ff                                                 20
        recv.queue_length                                       16777216
        recv.write_batch_size                                    1048576
        removal_suspend_progress                                       0
        remove_max_segment                                      16777216
        resilver_disable_defer                                         0
        resilver_min_time_ms                                        3000
        scan_blkstats                                                  0
        scan_checkpoint_intval                                      7200
        scan_fill_weight                                               3
        scan_ignore_errors                                             0
        scan_issue_strategy                                            0
        scan_legacy                                                    0
        scan_max_ext_gap                                         2097152
        scan_mem_lim_fact                                             20
        scan_mem_lim_soft_fact                                        20
        scan_strict_mem_lim                                            0
        scan_suspend_progress                                          0
        scan_vdev_limit                                          4194304
        scrub_min_time_ms                                           1000
        send.corrupt_data                                              0
        send.no_prefetch_queue_ff                                     20
        send.no_prefetch_queue_length                            1048576
        send.override_estimate_recordsize                              0
        send.queue_ff                                                 20
        send.queue_length                                       16777216
        send.unmodified_spill_blocks                                   1
        send_holes_without_birth_time                                  1
        slow_io_events_per_second                                     20
        spa.asize_inflation                                           24
        spa.discard_memory_limit                                16777216
        spa.load_print_vdev_tree                                       0
        spa.load_verify_data                                           1
        spa.load_verify_metadata                                       1
        spa.load_verify_shift                                          4
        spa.slop_shift                                                 5
        space_map_ibs                                                 14
        special_class_metadata_reserve_pct                            25
        standard_sm_blksz                                         131072
        super_owner                                                    0
        sync_pass_deferred_free                                        2
        sync_pass_dont_compress                                        8
        sync_pass_rewrite                                              2
        sync_taskq_batch_pct                                          75
        top_maxinflight                                             1000
        traverse_indirect_prefetch_limit                              32
        trim.extent_bytes_max                                  134217728
        trim.extent_bytes_min                                      32768
        trim.metaslab_skip                                             0
        trim.queue_limit                                              10
        trim.txg_batch                                                32
        txg.history                                                  100
        txg.timeout                                                    5
        unflushed_log_block_max                                   131072
        unflushed_log_block_min                                     1000
        unflushed_log_block_pct                                      400
        unflushed_log_txg_max                                       1000
        unflushed_max_mem_amt                                 1073741824
        unflushed_max_mem_ppm                                       1000
        user_indirect_is_special                                       1
        validate_skip                                                  0
        vdev.aggregate_trim                                            0
        vdev.aggregation_limit                                   1048576
        vdev.aggregation_limit_non_rotating                       131072
        vdev.async_read_max_active                                     3
        vdev.async_read_min_active                                     1
        vdev.async_write_active_max_dirty_percent                     60
        vdev.async_write_active_min_dirty_percent                     30
        vdev.async_write_max_active                                    5
        vdev.async_write_min_active                                    1
        vdev.bio_delete_disable                                        0
        vdev.bio_flush_disable                                         0
        vdev.cache_bshift                                             16
        vdev.cache_max                                             16384
        vdev.cache_size                                                0
        vdev.def_queue_depth                                          32
        vdev.default_ms_count                                        200
        vdev.default_ms_shift                                         29
        vdev.file.logical_ashift                                       9
        vdev.file.physical_ashift                                      9
        vdev.initializing_max_active                                   1
        vdev.initializing_min_active                                   1
        vdev.max_active                                             1000
        vdev.max_auto_ashift                                          14
        vdev.min_auto_ashift                                           9
        vdev.min_ms_count                                             16
        vdev.mirror.non_rotating_inc                                   0
        vdev.mirror.non_rotating_seek_inc                              1
        vdev.mirror.rotating_inc                                       0
        vdev.mirror.rotating_seek_inc                                  5
        vdev.mirror.rotating_seek_offset                         1048576
        vdev.ms_count_limit                                       131072
        vdev.nia_credit                                                5
        vdev.nia_delay                                                 5
        vdev.queue_depth_pct                                        1000
        vdev.read_gap_limit                                        32768
        vdev.rebuild_max_active                                        3
        vdev.rebuild_min_active                                        1
        vdev.removal_ignore_errors                                     0
        vdev.removal_max_active                                        2
        vdev.removal_max_span                                      32768
        vdev.removal_min_active                                        1
        vdev.removal_suspend_progress                                  0
        vdev.remove_max_segment                                 16777216
        vdev.scrub_max_active                                          3
        vdev.scrub_min_active                                          1
        vdev.sync_read_max_active                                     10
        vdev.sync_read_min_active                                     10
        vdev.sync_write_max_active                                    10
        vdev.sync_write_min_active                                    10
        vdev.trim_max_active                                           2
        vdev.trim_min_active                                           1
        vdev.validate_skip                                             0
        vdev.write_gap_limit                                        4096
        version.acl                                                    1
        version.ioctl                                                 15
        version.module                         v2023012500-zfs_9ef0b67f8
        version.spa                                                 5000
        version.zpl                                                    5
        vnops.read_chunk_size                                    1048576
        vol.mode                                                       2
        vol.recursive                                                  0
        vol.unmap_enabled                                              1
        wrlog_data_max                                        6861138328
        xattr_compat                                                   1
        zap_iterate_prefetch                                           1
        zevent.len_max                                               512
        zevent.retain_expire_secs                                    900
        zevent.retain_max                                           2000
        zfetch.max_distance                                     67108864
        zfetch.max_idistance                                    67108864
        zil.clean_taskq_maxalloc                                 1048576
        zil.clean_taskq_minalloc                                    1024
        zil.clean_taskq_nthr_pct                                     100
        zil.maxblocksize                                          131072
        zil.nocacheflush                                               0
        zil.replay_disable                                             0
        zil.slog_bulk                                             786432
        zio.deadman_log_all                                            0
        zio.dva_throttle_enabled                                       1
        zio.exclude_metadata                                           0
        zio.requeue_io_start_cut_in_line                               1
        zio.slow_io_ms                                             30000
        zio.taskq_batch_pct                                           80
        zio.taskq_batch_tpq                                            0
        zio.use_uma                                                    1
VDEV cache disabled, skipping section
ZIL committed transactions:                                         1.3k
        Commit requests:                                              79
        Flushes to stable storage:                                    79
        Transactions to SLOG storage pool:            0 Bytes          0
        Transactions to non-SLOG storage pool:        2.4 MiB         78
zef
Update:
Stopping the copy job and restarting the nfs service also seems to reset it back to top speed. Possible NFS issue?
I think you're vastly underestimating the amount of RAM needed for dedup.
I think what you're seeing is the system starting to gasp for air as it runs out of RAM to do all the jobs you're asking it to do at the same time.
zef
Thanks! I do enjoy pushing systems to their limits :) Where would you recommend I check to see if the system is "gasping for air" in logs or stats? What am I looking for?
The arc_summary already shows that you're pushing ARC to the limit at 23.5 GB of your 32 GB... that leaves little for nfs and the system in total (about 8GB), let alone the dedup function itself, which could be demanding several GB or even more.
I don't think there's really anywhere to look for more evidence as it's already in front of you.
Some more reading on dedup is probably in order.
You should probably start here:
and in the linked article:
Are you using a dedup VDEV?
zef
Excellent reading! Thanks for the links. Those special vdev's are really fancy and it was nice to get a refresher on dedupliation.
No, I'm not using any special dedup, metadata, or log VDEVs.
4 disks > 1 vdev > 1 pool > 2 datasets
In hindsight (thanks to the info you shared) I would have planned in some additional special vdevs and possibly a new pool for the dedup data. I never planned on needing/enabling dedup tho so I never gave much thought to metadata management at the time. Since, building my TrueNAS, I have generated a bunch of duplicated data from a system I am backing up daily. I wanted to have point-in-time functionality so a simple rsync wasnt an option, but I also didnt want to store a bunch of copied data - hence the new dedup pool for these backups.
At this point, I've copied most of the 1TB data out of the old un-deduped dataset and into the new deduped dataset. Have to say that I'm more than pleased with the results. 7.0x dedup rate, 800 GB > 100 GB, impressive! I still think it was the right thing to do despite the overwhelming general opinion that "deduping is more trouble than it's worth."
I suppose tho I'm still struggling to believe that the slowdowns I saw were a result of not enough memory. Arc will use what its told to. In this case its the default setting- which is 75% of all total RAM or 24GB. Most of that was taken up by the (highly variable and optional) MFU and MRU caches. The metadata table from the ARC summary only shows it was about 1GB in size. The remaining 8 GB, should be MORE than enough to run basic OS functions like NFS and driver management. In fact, based on the data above I would argue I could get away with much LESS memory at the cost of reduced speeds and higher cache miss ratios. The fact that the slowdown was abrupt, and not a gradual curve, makes me think I hit a limitation elsewhere. What's even more odd is if you look from the graph, the slowdown occurs on the READING of data from the dataset that is not using deduplication, instead of the writing and dedup phase like you would expect. The slowdown doesn't improve over time until an action is taken. And finally, why does rebooting the system - a complete reset of the entire cache - result in an immediate restoration of speeds despite having to rebuild the cache's from scratch. With that said, I'm morning leaning towards this is a random bug of nfs, but I haven't a clue to look where to look to confirm it.
Thanks for the help and recommendations! Like I said earlier, I'm done pushing boatloads of data around at this point so I probably won't experience the slowdown again but if anyone is curious as to what happened or would like any logs to analyze, I'm happy to provide.
Cheers!
