niclas197
- Jul 29, 2011
Hey,
I'm running a litte bit short on storage here on my HP Microserver and I thought of using one of the many available 4-Bay RAID cases but I'm not sure what setup I have to use in order to use ZFS on it.
I think that it would be required to adress each disk individually (i guess that is what JBOD means). Is this possible with USB 3.0 and are there any (half size, half height) PCIe Controller that are supported with FreeNAS? Are there any recommendations on what Raid Case to use?
The HP Microserver also has an eSATA port but it does not support port multiplication and my understanding is that FreeNAS does not support it well anyways (or is there a PCIe Controller (half size, half height) that supports eSATA port multiplication)
Are there any alternatives?
