Hi guys,
I have a HP MicrosServer running FreeNAS 9.3 very happily... trouble is that I am running out of space on my current pool and have no room to add drives inside the server; I'd need to add an extra 2 discs minimum (for redundancy) but would prefer to have room for 4 or more. USB is a no-no, so eSATA is probably the way to go. And budget is limited (the MicroServer is used for long-term storage to space is much more important than speed). The pool is 4x2TB as RAID-Z2 so I guess I could replace in turn two of the discs by e.g. 4 or 5TB HDDs which would give me another 2 or 3TB of space on the pool; but then I'd end up with 2x2TB discs doing nothing, so I'd rather "add" than "replace".
Having thought about it a bit, and trawled the forum, it seems to me that the best way forward would be to add an IBM M1015 / LSI adapter and connect an external eSATA enclosure with the extra discs. Two minutes of Googling bring back hundreds of 4- 5- or 8-bay enclosures, but they pretty much all seem to have some sort of RAID support and a single eSATA port which may or may not work with the M1015, so:
- is there another option (maybe firewire?)
- does anyone know of an X-bay, X-ports enclosure, thus guaranteeing that I can access the discs as JBOD?
- if not, can someone recommend an enclosure (X-bay but with only one eSATA port at the back) that is known to work with an IBM/LSI adapter?
Thanks in advance,
Olivier
Thanks in advance,
Olivier
