Russell Coight
- Jul 3, 2014
I'm looking for recommendations for a SAS HBA that has external ports.
We have an unused HP DL360 G5 that we would like to use as a FreeNAS server. It will connect to an unused disk enclosure hence the need for external SAS ports.
The enclosure has 12 x 1TB drives with 2 SAS ports. Ideally we would like 2 cards with 1 port for some redundancy. If there is a suitable card that has one port so we can get 2, it will need to be half height and come with a full height and half height bracket as the DL360 has one half height and one full height slot.
Here's one card I came across that we can get relatively easily, apologies for the PDF:
http://www.oracle.com/us/products/s...rking/6gb-sas-pcie-hba-external-ds-186803.pdf
It uses a LSI2008 chipset, from what I've read this chipset will work but I need to flash it to IT mode? Can this card be flashed? Although it has 2 ports it's still an option, will probably just go with one of these.
There isn't a big budget for this, already have the cables though.
thanks
thanks
