Expand ZFS Volume with 2 Disks ?
xImran
I am using FreeNAS 8.2.0 and currently have only 2 x 1TB disk mounted as ZFS Volume (Mirror). Now I need to increase the available storage so what's the best way to do it?
1) add another 1TB HDD, will it increase the available capacity?
2) add 2 x 1TB HDD, how?
Thanks in advance for your help.
None of the above. Check out the presentation in my signature.
xImran
Thanks noobsauce80
Your guide is very clear and now I understand the storage mechanism. I made the same mistake like other beginners to not fully understand the file system in FreeNAS before jumping into it. Anyway it means either I replace the drives with larger capacity or get more drives and create new Volume and add it to pool.
I think RaidZ is good enough for me.
