I have 8 x 1TB disks, I have played with this in VMware and I am now ready to bring this to life. What is the best performance and redundancy mix, I am doing ZFS
1. RAIDZ2, allows 2 disk failures seems to be fast enough at least in VMware I get 30-35MBs (5.8TB of storage)
2. zpool with 4 mirror arrays in it, I seems to get a little speed bump 35-40MBs. That could just be VMware and the fact that all my VMDKs are on the same LUN so I only see marginal speed increase (3.4 TB of Storage) seems to allow 4 drive failures, as long as both drives in a single mirror don't fail at the same time.
Also a second question, why when I setup a ZFS mirror with 8 x 1 TB disk does it make a 1TB share with 7 disk failure capacity instead of making a ~3.4TB share with 4 disk failure capacity? Do I really have to keep making 2 disk mirrors and adding them to the pool to get to option #2?
Last and least important question, does ZFS stripe in FreeNAS allow you to fail 1 drives out, it seemed like in my testing in VMware it did?
Thanks for the help.
HARDWARE SPECS:
FreeNAS 8.0.1 x64
6GB PC2-6400
Core 2 Duo, 2.0GHz
2 Promise 4 Port SATA adapters.
HARDWARE SPECS:
FreeNAS 8.0.1 x64
6GB PC2-6400
Core 2 Duo, 2.0GHz
