Execute permissions NFS
el_pedriyo
I am currently having some trouble when trying to execute a .sh in my VM which is located in my freenas dataset mounted with NFS. My dataset has UNIX permission type with 777 permissions with the root user set, and the sharing NFS has the maproot also with the root user. This is the output of my VM:
root@services:/mnt/media# ls -ln
total 254
-rwxrwxrwx 1 0 0 314 nov 2 21:13 plex_scan
As you can see the file has execute permissions, but when I try to execute it with root it doesn't allow me.
Any idea on why?
Kind regards,
Pedro
droeders
If you show us the terminal output when you try to execute the script, we might be able to help you.
Also, please post the contents of the plex_scan file in code tags.
fracai
The NFS share is probably mounted with "noexec" as one of the options. What system are you mounting it to? What command or configuration did you use to do that?
