justgosh
- May 23, 2013
I started by building a system to test various applications. My current configuration has evolved over the past few years, a few applications have been kept for daily use but for the most part it's a test environment.
As I've been building, some issues that I didn't understand initially have been created. I would like to work the issues out and avoid anything that it's obvious to someone with more experience. I'm hosting several VMs but have been running into throughput issues despite their low utilization. I had iSCSI performance issues so I'm currently using NFS and CIFS (occasional file management).
I'm currently running 5 WD Reds in Z1 which I will add a drive to and migrate to Z2. I've added SSD log and cache drives, however, I didn't use a PLP drive. Additionally, the SSD drives selected do not have the wear tolerance required to sustain the configuration. Finally, I'm adding a 10GbE network to free up some switch ports.
ESXi VMs
AD/DHCP/DNS
Ubuntu 16.04 Gitlab
Plex/Sonarr/DVR1
Plex/DVR2
Ubuntu 16.04 Docker app server
MacOS test 1
Windows 10 test 1
vCenter appliance
Fonality appliance
Supermicro X8SIL - Intel Xeon X3450 - KVR1333D3Q8R9S/8G 32GB ECC RAM - M1015 - 6 x 3TB WD Red - X540-T2
I also have a few Samsung 850 Pro 250GB and Sandisk Ultra 240GB that I'm not sure how to use in this setup. I have room for 2 more SATA drives on the controller.
I'm looking at adding a PLP drive. I'm looking for the best way to proceed and considering a DC P3700 or similar but thought I would ask for suggestions before I spend any money.
edit: typo on HBA model
ESXi VMs
AD/DHCP/DNS
Ubuntu 16.04 Gitlab
Plex/Sonarr/DVR1
Plex/DVR2
MacOS test 1
Windows 10 test 1
vCenter appliance
Fonality appliance
