packerbackermk
- Feb 13, 2019
This is a 3tb sas drive that I have plugged into an LSI9211 that is flashed to IT mode. I have used this card before in this system. I tried replacing the cable to be sure but this error is thrown when trying to wipe or create a zfs pool with the drive with both sets of cables.
Here is the error:
Is this drive toast?
Here is the error:
File "./freenasUI/storage/views.py" in disk_wipe
866. wait_job(c, DISK_WIPE_JOB_ID)
File "./freenasUI/middleware/util.py" in wait_job
29. raise JobFailed(job['error'])
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
42. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
163. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
870. raise MiddlewareError(_('Disk wipe job failed: %s') % str(e.value))
Exception Type: MiddlewareError at /legacy/storage/disks/wipe/da1/
Exception Value: [MiddlewareError: Disk wipe job failed: Command '('gpart', 'create', '-s', 'gpt', '/dev/da1')' returned non-zero exit status 1.]Is this drive toast?
