Hello all,
I have a serious problem going on with FreeNAS 11.1. I have a dying hard drive that I am trying to replace. However, whenever I try to offline the hard drive it gives the no valid replica error:
Ok fine, I will then detach the pool,erase, swap the drive, rebuild and start over. I have good backups not a problem.
NO, not going to happen. I get a device busy error
The files are no longer accessible over the network, and I still have to replace this dying hard drive. Anyone know what is going on? What can I do?
Thank you in advance for any and all help with this matter.
Environment: Software Version: FreeNAS-11.1-RELEASE (dc7d195f4) Request Method: POST Request URL: http://192.168.1.5/storage/zpool-Media/disk/offline/gptid/70541891-e6cf-11e7-8c7e-002564fcc135/ Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 42. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/storage/views.py" in disk_offline 641. notifier().zfs_offline_disk(volume, label) File "./freenasUI/middleware/notifier.py" in zfs_offline_disk 1065. raise MiddlewareError('Disk offline failed: "%s"' % error) Exception Type: MiddlewareError at /storage/zpool-Media/disk/offline/gptid/70541891-e6cf-11e7-8c7e-002564fcc135/ Exception Value: [MiddlewareError: Disk offline failed: "cannot offline gptid/70541891-e6cf-11e7-8c7e-002564fcc135: no valid replicas, "]
Environment: Software Version: FreeNAS-11.1-RELEASE (dc7d195f4) Request Method: POST Request URL: http://192.168.1.5/storage/detach/1/ Traceback: File "./freenasUI/middleware/notifier.py" in __rmdir_mountpoint 2740. os.rmdir(path) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 42. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/storage/views.py" in volume_detach 714. cascade=form.cleaned_data.get('cascade', True)) File "./freenasUI/storage/models.py" in delete 390. systemdataset=systemdataset, File "./freenasUI/storage/models.py" in _delete 369. n.volume_destroy(self) File "./freenasUI/middleware/notifier.py" in volume_destroy 1203. self.__rmdir_mountpoint(vol_mountpath) File "./freenasUI/middleware/notifier.py" in __rmdir_mountpoint 2743. % (path, str(ose), )) Exception Type: MiddlewareError at /storage/detach/1/ Exception Value: [MiddlewareError: Failed to remove mountpoint /mnt/Media: [Errno 16] Device busy: '/mnt/Media']
